Participant jamead
Petalinux 14.2 Error with petalinux-config -c rootfs ERROR: Failed to run linux system auto config.
$ petalinux-config -c rootfs
INFO: Checking component...
INFO: Config linux/rootfs
[INFO ] config linux/rootfs
*** End of the configuration.
/opt/petalinux/petalinux-v2014.2-final/tools/hsm/bin/unwrapped/lnx64.o/hsm: error while loading shared libraries: libgomp.so.1: cannot open shared object file: No such file or directory
Re: Petalinux 14.2 Error with petalinux-config -c rootfs ERROR: Failed to run linux system auto config.
This looks like a host issue like you may be using an unsupported OS or there was an install issue with Petalinux (with the dependent libs). There are a number of threads on the forum with similar topics that you might review.
Scholar sampatd
Observer subpixel
Did you solve the problem? I have same issue on PetaLinux 14.2 and Ubuntu 13.10.
Visitor mrsouth
On 32bit Ubuntu, install package libgomp1, on 64bit Ubuntu, install package lib32gomp1. A table of required tools and libraries can be found on page 10 UG976 PetaLinux Installation Guide (v2014.2).
And do check on the link sampatd provided above. It helps me a lot when installing PetaLinux on Ubuntu.
On Redhat and CentOS 6.4 and 64 bit, issue the command sudo yum install libgomp.i686
