joseer
Voyager
Voyager
Petalinux 2010.1 boot error - No partition table - mmc 1
I'm trying to port my petalinux 2019.2 project to 2020.1, for a Zynq Ultrascale+ device. I have not bsp for the third party dev board I'm using so I followed next steps:
- Created a petalinux 2020.1 blank project based on the zynqMP template.
- Import Vivado 2020.1 generated hardware config.
- Copy system-user.dtsi from 2019.2.
- Build and package images.
All good till the booting point where I've got a few errors and one of them is No partition table - mmc 1 which I don't understand because there's partition table in the SD card, i.e with same SD card petalinux 2019.2 boots without problems.
The boot log is:
Xilinx Zynq MP First Stage Boot Loader
Release 2020.1   Sep  8 2020  -  10:38:03
NOTICE:  ATF running on XCZU5EV/silicon v4/RTL5.1 at 0xfffea000
NOTICE:  BL31: v2.2(release):v1.1-5588-g5918e656e
NOTICE:  BL31: Built : 14:13:45, Sep  8 2020
U-Boot 2020.01 (Sep 09 2020 - 08:41:26 +0000)
Board: Xilinx ZynqMP
DRAM:  2 GiB
PMUFW:  v1.1
EL Level:       EL2
Chip ID:        zu5ev
NAND:  0 MiB
MMC:   mmc@ff160000: 0, mmc@ff170000: 1
In:    serial@ff000000
Out:   serial@ff000000
Err:   serial@ff000000
Bootmode: SD_MODE1
Reset reason:   SOFT
Net:
ZYNQ GEM: ff0e0000, mdio bus ff0e0000, phyaddr 1, interface rgmii-id
Warning: ethernet@ff0e0000 using MAC address from DT
eth0: ethernet@ff0e0000
switch to partitions #0, OK
mmc1 is current device
** No partition table - mmc 1 **
## Executing script at 20000000
Wrong image format for "source" command
SCRIPT FAILED: continuing...
mmc0(part 0) is current device
** No partition table - mmc 0 **
SF: Detected n25q512a with page size 512 Bytes, erase size 128 KiB, total 128 MiB
device 0 offset 0x3e80000, size 0x80000
SF: 524288 bytes @ 0x3e80000 Read: OK
no devices available
starting USB...
Bus dwc3@fe200000: Register 2000440 NbrPorts 2
Starting the controller
USB XHCI 1.00
scanning bus dwc3@fe200000 for devices... 3 USB Device(s) found
       scanning usb for storage devices... 0 Storage Device(s) found
Device 0: unknown device
Device 1: unknown device
scanning bus for devices...
SATA link 0 timeout.
SATA link 1 timeout.
AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
flags: 64bit ncq pm clo only pmp fbss pio slum part ccc apst
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
Retry time exceeded; starting again
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/01-00-0a-35-00-22-01
*** ERROR: `serverip' not set
Retrieving file: pxelinux.cfg/00000000
Retrieving file: pxelinux.cfg/default-arm-zynqmp-zynqmp
ZynqMP>
Any ideas about what I could be missing?
Thanks in advance.
patocarr
Hi @joseer
  How was the SD card partitioned? I recently had trouble with an eMMC card being partitioned in a way that worked as a mounted drive, but it would not boot from it. The memory was partitioned in Linux, i.e. /dev/mmcblk0 then formatted it as FAT32. The key to fix it was to format (mkfs.vfat) the actual partition /dev/mmcblk0p1 instead. It was U-Boot that had trouble reading from the memory and reported having no partition, though the message was different iirc. This is the post with details Boot-from-QSPI-load-image-ub-from-MMC
  At this point I would try re-formatting the SD card in a different way. See the formatting details in the solution in the above post.
-Pat
Give kudos if helpful. Accept as solution if it solves your problem.
https://tuxengineering.com/blog
jrhtech
Voyager
Voyager
Did you copy boot.scr onto the SD card FAT partition? I think that's what 'Wrong image format for "source" command' is telling you.
jeff
joseer
Voyager
Voyager
Hi @jrhtech ,
Thanks for your answer, yes I did, in the SD card there're the next files: BOOT.BIN, image.ub and boot.scr
patocarr
Hi @joseer
  Can you access the mmc from U-Boot? i.e. using the 'mmc' command.
-Pat
joseer
Voyager
Voyager
Hi @patocarr,
Yes I can access, I've got the next output:
ZynqMP> fatls mmc 1
  9055520   BOOT.BIN
 47929844   image.ub
     2007   boot.scr
            System Volume Information/
patocarr
@joseer
  So it looks like the mmc is fine, hardware-wise. The partition related message may be because it expects the mmc/SD to have more partitions and there may be just one partition.
  The issue then narrows down to the boot.scr script, which is suspect. Let's try to manually load it from U-Boot, and then execute it:
ZynqMP> load mmc 1:0 0x200000 boot.scr
ZynqMP> source 0x200000
  I suspect this would throw the same error message, pointing to the boot.scr being somewhat malformed/corrupted.
-Pat
jrhtech
Voyager
Voyager
Did you edit the boot.scr manually?  This will break it also.
It sounds like the boot.scr is wrong.  From u-boot, you can run make sure the boot script is getting passed the correct args by setting boot_targets to mmc1 and then run bootcmd_mmc1
jeff
joseer
Voyager
Voyager
Hi @jrhtech @patocarr , thanks for your answers, it looks like the issue could be around boot.scr...
I tried the commands as suggested and I've got:
2007 bytes read in 18 ms (108.4 KiB/s)
## Executing script at 00200000
Bad Linux ARM64 Image magic!
@patocarr are those errors what you suspected? ....after loading it into mmc1  I was expecting to see the errors in mmc1 not in mmc0...not sure what's going on
is there any petalinux config I'm missing?
joseer
Voyager
Voyager
The boot.src content is:
# This is a boot script for U-Boot
# Generate boot.scr:
# mkimage -c none -A arm -T script -d boot.cmd.default boot.scr
for boot_target in ${boot_targets};
do
	if test "${boot_target}" = "jtag" ; then
		booti 0x00200000 0x04000000 0x00100000
		exit;
	fi
	if test "${boot_target}" = "mmc0" || test "${boot_target}" = "mmc1" ; then
		if test -e ${devtype} ${devnum}:${distro_bootpart} /image.ub; then
			fatload ${devtype} ${devnum}:${distro_bootpart} 0x10000000 image.ub;
			bootm 0x10000000;
			exit;
                fi
		if test -e ${devtype} ${devnum}:${distro_bootpart} /Image; then
			fatload ${devtype} ${devnum}:${distro_bootpart} 0x00200000 Image;;
		fi
		if test -e ${devtype} ${devnum}:${distro_bootpart} /system.dtb; then
			fatload ${devtype} ${devnum}:${distro_bootpart} 0x00100000 system.dtb;
		fi
		if test -e ${devtype} ${devnum}:${distro_bootpart} /rootfs.cpio.gz.u-boot; then
			fatload ${devtype} ${devnum}:${distro_bootpart} 0x04000000 rootfs.cpio.gz.u-boot;
			exit;
		fi
		booti 0x00200000 - 0x00100000
		exit;
	fi
	if test "${boot_target}" = "xspi0" || test "${boot_target}" = "qspi" || test "${boot_target}" = "qspi0"; then
		sf probe 0 0 0;
		if test "image.ub" = "image.ub"; then
			sf read 0x10000000 0xF00000 0x6400000;
			bootm 0x10000000;
			exit;
		fi
		if test "image.ub" = "Image"; then
			sf read 0x00200000 0xF00000 0x1D00000;
			sf read 0x04000000 0x4000000 0x4000000
			exit;
		fi
		exit;
	fi
	if test "${boot_target}" = "nand" || test "${boot_target}" = "nand0"; then
		nand info
			nand read 0x10000000 0x4100000 0x6400000;
			bootm 0x10000000;
			exit;
		fi
			nand read 0x00200000 0x4100000 0x3200000;
			nand read 0x04000000 0x7800000  0x3200000;
			exit;
		fi
	fi
done
 Any ideas?
Thanks!
patocarr
Hi @joseer
  The boot.scr contents look okay, but the file has a binary header that's not present in your post. That header is important and may be the reason U-Boot complains about not being a proper script.
  The boot.scr is generated under the ./images/linux directory and shouldn't be edited before copying it to flash.
-Pat
joseer
Voyager
Voyager
Hi @patocarr ,
Thanks for your reply,
What binary header file?, could you please expand that a bit?
(Just to clarify, the boot.scr is as is created by petalinux it hasn't been edited)
patocarr
Hi @joseer
  So to recap, from your first post U-Boot selects the mmc1 and attempts to read the boot.scr:
  But when you do it manually, it does read it. But when it executes it, it tries to load files from mmc0:
  It looks like the device selected to boot from changes to mmc0:
			bootm 0x10000000;
			exit;
                fi
  In U-Boot, try printing the values of these variables:
ZynqMP> printenv boot_targets
ZynqMP> printenv devtype ZynqMP> printenv devnum ZynqMP> printenv distro_bootpart
  My suspicion is that devnum is switching to mmc0 somehow when run manually. But still can't explain why the bad partition messages are coming up.
-Pat
joseer
Voyager
Voyager
Hi @patocarr ,
Thanks again for your help,
Yes, it is very weird it looks like always it is trying to boot from mmc0 even if I force it to do it from mmc1, and the the partition is fine I don't understand that error..till now upgrading Petalinux versions has been relatively straight forward but 2020.1 is being very challenging.....
I've printed the variables and I've got:
boot_targets=mmc1 jtag mmc1 mmc0 qspi0 nand0 usb0 usb1 scsi0 pxe dhcp
## Error: "devtype" not defined
## Error: "devnum" not defined
## Error: "distro_bootpart" not defined
Any ideas what is going on with those variables which are not defined?
I've got the impression something is missing in the config....?
patocarr
Hi @joseer
  Something is wrong with the u-boot configuration then; those variables should have been defined.
  When doing petalinux-config, the "u-boot configuration -> U-boot config" should be set to "other" and the target should be "xilinx_zynqmp_virt_defconfig". Also, in the "Autoconfig settings", make sure u-boot is set to _not_ autoconfig (i.e. unchecked).
-Pat
jrhtech
Voyager
Voyager
@patocarr I would disagree with the vars, only boot_targets should be set, the others
are determined when running
@joseer I would try running like this so you can see if you uboot is doing the right thing
setenv boot_targets mmc1
run bootcmd_mmc1
you can also modify boot.cmd.default.initrd in u-boot/u-boot-zynq-scr/ and add echos to the boot.scr.
jeff
joseer
Voyager
Voyager
Thanks for the answers,
@patocarr ,  the petalinux-config looks ok, same setting as you're suggesting (I think it is default config)...
@jrhtech, I ran the commands and the only error is:
ZynqMP> setenv boot_targets mmc1
ZynqMP> run bootcmd_mmc1
However the partition table is ok and the files are there:
ZynqMP> fatls mmc 1
 47891180   image.ub
     2007   boot.scr
  9042028   BOOT.BIN
3 file(s), 1 dir(s)
I'm lost with this, any clues would be much appreciated...
jrhtech
Voyager
Voyager
  it’s like it doesn’t even see the boot script.   I would try putting in the echos to see if you can get any info.
  I would also try a different SD and make sure to set the boot flag in fdisk.   I don’t actually know why this does I just know I set it based on some Xilinx document.
  And the of course, look at the uboot source and try to figure out what is happening.
jeff
patocarr
Hi @joseer
-Pat
