Petalinux 2014.2 dts phy compatibility missing
In the ps.dtsi
Petalinux v2014.2
ps7_ethernet_0: ps7-ethernet@e000b000 {
#address-cells = <1>;
#size-cells = <0>;
clock-names = "ref_clk", "aper_clk";
clocks = <&clkc 13>, <&clkc 30>;
compatible = "xlnx,ps7-ethernet-1.00.a";
interrupt-parent = <&ps7_scugic_0>;
interrupts = <0 22 4>;
local-mac-address = [00 0a 35 00 00 00];
phy-mode = "rgmii-id";
reg = <0xe000b000 0x1000>;
xlnx,ptp-enet-clock = <0x69f6bcb>;
xlnx,enet-reset = "";
xlnx,eth-mode = <0x1>;
xlnx,has-mdio = <0x1>;
mdio {
#size-cells = <0>;
COMPARED TO
Petalinux v2013.10
#size-cells = <0>;
local-mac-address = [ 00 0a 35 00 d6 6c ];
phy-handle = <&phy0>;
xlnx,ptp-enet-clock = <111111115>;
mdio {
#size-cells = <0>;
phy0: phy@7 {
compatible = "marvell,88e1116r";
device_type = "ethernet-phy";
reg = <7>;
Phy compatible is missing...
This is a autogenerated file by petalinux....
After boot, ifconfig cannot configure interface properly for DHCP
Is this a bug or is there a special config I have to do?
Re: Petalinux 2014.2 dts phy compatibility missing
This is done by design. In the past we just blindly assumed you were using a Marvell PHY (since all of our evaluation boards do) and set up the DTS to correspond to *that* PHY.
Going forward we're trying to be more generic and separate what we can automatically determine about the system from your HW platform files / SW platform description and what is board-specific that you'll need to specify on your own.  This PHY is one such example.  Another good example would be SPI or I2C devices on the board.
These AR's are probably right up your alley:
http://www.xilinx.com/support/answers/61116.html
http://www.xilinx.com/support/answers/61117.html
this space intentionally left blank
