04-29-2015 12:20 AM
I have some troubles loading the flash idcode from an spi-flash in u-boot.
Setup: fpga is on a custom pcb. hw system with microblaze 100MHz, axi qspi module running standard mode, transaction-width 8, ratio 16x1, and with fifo with 16 depth.
When booting (with petalinux-boot --jtag --u-boot) I first get a XILSPI error: XILSPI error: spi_xfer: Xfer timeout when trying to fetch the id-code. This is probably from the following lines in the xilinx_spi.c driver: spi_xfer () function
while (timeout && readl(&xilspi->regs->spisr) & SPISR_RX_EMPTY) { timeout--; udelay(1); } if (!timeout) { printf("XILSPI error: %s: Xfer timeout\n", __func__); return -1; }
Later after "Hit any key to stop autoboot", the flash ID is successfully read. Here is the output:
U-Boot 2014.07 (Apr 29 2015 - 08:22:41) SDRAM : Icache:ON Dcache:ON U-Boot Start:0xfff00000 XILSPI error: spi_xfer: Xfer timeout SF: Failed to get idcodes *** Warning - spi_flash_probe() failed, using default environment In: ttyUL0 Out: ttyUL0 Err: serial Net: aximac.40c00000 MAC: 00:0a:35:00:22:01 Warning: Your board does not use generic board. Please read doc/README.generic-board and take action. Boards not upgraded by the late 2014 may break or be removed. U-BOOT for 2petalinuxtest BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 BOOTP broadcast 5 Retry count exceeded Hit any key to stop autoboot: 0 SF: Detected MX25L25635F with page size 256 Bytes, erase size 64 KiB, total 32 MiB SF: 6291456 bytes @ 0x460000 Read: OK Wrong Image Format for bootm command ERROR: can't get kernel image!
I had to add #define CONFIG_SPI_FLASH_MACRONIX in /subsystems/linux/configs/u-boot/platform-top.h to support the macronix flash.
Also I have a warning that my board does not use a generic board and refers me to README.generic-board that tells me to
arch/<arch>/config.mk file to include: __HAVE_ARCH_GENERIC_BOARD := y and test it with a suitable board, as follows. Adding Support for your Board ----------------------------- To enable generic board for your board, define CONFIG_SYS_GENERIC_BOARD in your board config header file.
Where is the board config header located, and is this something that is needed to be changed or a warning due to not getting read from the flash?
In advance, thanks for all the help!
