Visitor srenich
Petalinux 2015.2.1 fresh install, build problem
I have a fresh install of Petalinux that does not build properly with an added package (unzip).
For the first attempt to build, I imported the hardware description, and configured (added several packages).  The build failed with warnings and errors:
[WARN ] WARNING: The following packages cannot be authenticated!
[WARN ] dpkg: warning: 'ldconfig' not found in PATH or not executable
[WARN ] dpkg: warning: 'start-stop-daemon' not found in PATH or not executable
[WARN ] dpkg: warning: overriding problem because --force enabled:
[ERROR] Errors were encountered while processing:
[ALL  ]  unzip
[ERROR] E: Sub-process /opt/pkg/petalinux-v2015.2.1-final/tools/packagemanager/bin/dpkg returned an error code (1)
[ERROR] make[2]: *** [.pkg_stagefs] Error 255
[ALL  ] make[2]: Leaving directory `/home/srenich/rfcc_pnlx/build/linux/rootfs/packages-repo'
[ERROR] make[1]: *** [sub_build_component_/none/packages-repo/single/plnx-repo] Error 2
[ALL  ] make[1]: Leaving directory `/home/srenich/rfcc_pnlx/build/linux/rootfs'
[ALL  ] make: *** [sub_build_component_/none/rootfs/single/petalinux-rootfs] Error 2
[ALL  ] make: Leaving directory `/home/srenich/rfcc_pnlx/build/linux'
When I run "petalinux-configure -c rootfs" and unselect "Filesystems packages/console_utils/unzip", the errors go away, but not the warnings.
Setup:
Vivado 2015.2.1 on Windows 10
Petalinux 2015.2.1 on CentOS 7 on a VM on same machine.
Installed versions of gcc, gawk and make are slightly newer than those listed in UG1144.
I have scoured the forums and found solutions to many similar problems.  I have installed several of the packages suggested there, but have not modified any makefiles.  No improvement.
In addition, the installed plnxcrc32 still does not work:
$ cd /opt/pkg/petalinux-v2015.2.1-final/tools/linux-i386/petalinux/bin/unexport/
$ ./plnxcrc32
Segmentation fault (core dumped)
I am attaching the verbose build logs for both with and without the unzip package.  In addition, I am attaching a list of installed packages (from "yum list install > installed_pkgs.txt").
Any help with this would be appreciated.
Steven
Similar posts:
https://forums.xilinx.com/t5/Embedded-Linux/2015-2-build-image-failure/m-p/646291#M13747
https://forums.xilinx.com/t5/Embedded-Linux/zedboard-BSP-build-fails-out-of-the-box/m-p/643127/highlight/true#M13527
https://forums.xilinx.com/t5/Embedded-Linux/petalinux-build-dpkg-error/m-p/679159/highlight/true#M15245
Visitor srenich
Re: Petalinux 2015.2.1 fresh install, build problem
Could this be a missing library?  I ran strace on plnxcrc32:
strace -o output.txt ./plnxcrc32
The output is:
execve("./plnxcrc32", ["./plnxcrc32"], [/* 48 vars */]) = 0
brk(0)                                  = 0x2517000
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f7d285ab000
access("/etc/ld.so.preload", R_OK)      = -1 ENOENT (No such file or directory)
open("/home/xbrbbot/ssw_tools/RHEL64/x86_64/lib/tls/x86_64/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/xbrbbot/ssw_tools/RHEL64/x86_64/lib/tls/x86_64", 0x7ffce7109b00) = -1 ENOENT (No such file or directory)
open("/home/xbrbbot/ssw_tools/RHEL64/x86_64/lib/tls/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/xbrbbot/ssw_tools/RHEL64/x86_64/lib/tls", 0x7ffce7109b00) = -1 ENOENT (No such file or directory)
open("/home/xbrbbot/ssw_tools/RHEL64/x86_64/lib/x86_64/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/xbrbbot/ssw_tools/RHEL64/x86_64/lib/x86_64", 0x7ffce7109b00) = -1 ENOENT (No such file or directory)
open("/home/xbrbbot/ssw_tools/RHEL64/x86_64/lib/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/xbrbbot/ssw_tools/RHEL64/x86_64/lib", 0x7ffce7109b00) = -1 ENOENT (No such file or directory)
open("tls/x86_64/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("tls/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("x86_64/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("libc.so.6", O_RDONLY|O_CLOEXEC)   = -1 ENOENT (No such file or directory)
open("/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=103825, ...}) = 0
mmap(NULL, 103825, PROT_READ, MAP_PRIVATE, 3, 0) = 0x7f7d28591000
close(3)                                = 0
open("/lib64/libc.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \34\2\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=2107816, ...}) = 0
mmap(NULL, 3932736, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f7d27fca000
mprotect(0x7f7d28180000, 2097152, PROT_NONE) = 0
mmap(0x7f7d28380000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1b6000) = 0x7f7d28380000
mmap(0x7f7d28386000, 16960, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f7d28386000
close(3)                                = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f7d28590000
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f7d2858e000
arch_prctl(ARCH_SET_FS, 0x7f7d2858e740) = 0
mprotect(0x7f7d28380000, 16384, PROT_READ) = 0
mprotect(0x7f7d285ac000, 4096, PROT_READ) = 0
munmap(0x7f7d28591000, 103825)          = 0
--- SIGSEGV {si_signo=SIGSEGV, si_code=SEGV_MAPERR, si_addr=0} ---
+++ killed by SIGSEGV (core dumped) +++
Any help would be appreciated.
Steven
Observer naveeng
Hi Steven,
You build log file with unzip package shows as below:
[ALL  ] dpkg: unzip-dev: dependency problems, but configuring anyway as you requested:
[ALL  ]  unzip-dev depends on unzip (= 1:6.0-r5); however:
[ALL  ]   Package unzip is not configured yet.
Can you please re-look to avoid any dependency problem?
The below two articles might give some clues on the similar problem:
http://www.xilinx.com/support/answers/63034.html
http://japan.zylinks.com/support/answers/66152.html
Naveen
Visitor srenich
Thanks to Naveen for help resolving this. I am posting the resolution here in case it helps someone. 1) Selecting the unzip package in the menuconfig (petalinux-config -c rootfs) causes the build to fail. This is a bug in dpkg in petalinux 2015.2. It is fixed in 2015.4. This is similar to the issue described in AR# 66152. 2) The program plnxcrc32 segfaults when called without an argument. While unexpected, this is normal behavior.
