Observer rgallic_incjet
Petalinux 2016.2 Import Hardware Configuration failure
I get the following error when I attempt to import the hardware design file generated by Vivado.
ERROR: [HDF 64-25] The hdf file has been tampered
ERROR: [Hsi 55-1451] Error: running open_hw_design.
Failed to open hardware design from /home/user/petalinux-v2016.2-final/MZ2Ricoh_V133_R007/subsystems/linux/hw-description/system.hdf
    while executing
"error "Failed to open hardware design from ${hdf}""
    (procedure "plnx_gen_hwsysconf" line 12)
    invoked from within
"${tclproc} ${cmdline}"
    invoked from within
"if { "[info procs ${tclproc}]" eq "${tclproc}"} {
} else {
    error "proc ${tclproc} doesn't exit."
    (file "/home/user/petalinux-v2016.2-final/MZ2Ricoh_V133_R007/build/linux/hw-description/hw-description.tcl" line 1486)
INFO: [Common 17-206] Exiting hsi at Thu Apr  6 15:38:18 2017...
Makefile:89: recipe for target '/home/user/petalinux-v2016.2-final/MZ2Ricoh_V133_R007/build/linux/Kconfig.syshw' failed
make: *** [/home/user/petalinux-v2016.2-final/MZ2Ricoh_V133_R007/build/linux/Kconfig.syshw] Error 1
ERROR: Failed to generate System hardware Kconfig file.
I am running Petalinux 2016.2.
The hdf file was generated from Vivado 2016.3.
Is the file generated by Vivado 2016.3 compatible with Petalinux 2016.2?
Do we need to downgrade Vivado to 2016.2?
Re: Petalinux 2016.2 Import Hardware Configuration failure
Regenerated hdf file using Vivado 2016.02.
Problem went away.
Problem went away.
Hi rgallic,
Can you explain how to regenerate hdf file?
I am also facing the same problem
Thanks, Aj.
