Petalinux 2016.3 USB not found
I have a problem with the USB Port of my carrier with an Xilinx zynq 7030 FPGA.
The USB 0 port is enabled in vivado and the drivers in Petalinux config too.
When I type in:
root@*******:~# lsusb
root@*******:~#
there is nothing
dmesg shows this output
root@*******:~# dmesg | grep -i usb
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
usbcore: registered new interface driver cdc_wdm
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
and in proc/bus there is no usb ->
root@******:/proc/bus# ls
input pci
I tried a lot to change the system-top device tree file, but no success.
How to fix this?
Thank you
Sebastian
Re: Petalinux 2016.3 USB not found
If it helps this is the system-top.dts:
/dts-v1/;
/include/ "system-conf.dtsi"
system-conf.dtsi
* CAUTION: This file is automatically generated by PetaLinux SDK.
* DO NOT modify this file
/include/ "skeleton.dtsi"
/include/ "zynq-7000.dtsi"
/include/ "pcw.dtsi"
/include/ "pl.dtsi"
model = "EMC2_LVTTL";
aliases {
serial0 = &uart1;
ethernet0 = &gem0;
spi0 = &qspi;
chosen {
bootargs = "console=ttyPS0,115200 earlyprintk";
stdout-path = "serial0:115200ns";
memory {
device_type = "memory";
reg = <0x0 0x40000000>;
&gem0 {
local-mac-address = [00 0a 35 00 1e 53];
&qspi {
#address-cells = <1>;
#size-cells = <0>;
flash0: flash@0 {
compatible = "micron,m25p80";
reg = <0x0>;
#size-cells = <1>;
spi-max-frequency = <50000000>;
partition@0x00000000 {
label = "boot";
reg = <0x00000000 0x00500000>;
partition@0x00500000 {
label = "bootenv";
reg = <0x00500000 0x00020000>;
partition@0x00520000 {
label = "kernel";
reg = <0x00520000 0x00a80000>;
partition@0x00fa0000 {
label = "spare";
reg = <0x00fa0000 0x00000000>;
the zynq-7000.dtsi
* Copyright (C) 2011 - 2014 Xilinx
* This software is licensed under the terms of the GNU General Public
* License version 2, as published by the Free Software Foundation, and
* may be copied, distributed, and modified under those terms.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
compatible = "xlnx,zynq-7000";
cpus {
#size-cells = <0>;
cpu0: cpu@0 {
compatible = "arm,cortex-a9";
device_type = "cpu";
reg = <0>;
clocks = <&clkc 3>;
clock-latency = <1000>;
cpu0-supply = <&regulator_vccpint>;
operating-points = <
/* kHz uV */
666667 1000000
333334 1000000
cpu1: cpu@1 {
reg = <1>;
clocks = <&clkc 3>;
pmu {
compatible = "arm,cortex-a9-pmu";
interrupts = <0 5 4>, <0 6 4>;
interrupt-parent = <&intc>;
reg = < 0xf8891000 0x1000 0xf8893000 0x1000 >;
regulator_vccpint: fixedregulator@0 {
compatible = "regulator-fixed";
regulator-name = "VCCPINT";
regulator-min-microvolt = <1000000>;
regulator-max-microvolt = <1000000>;
regulator-boot-on;
regulator-always-on;
amba: amba {
compatible = "simple-bus";
#size-cells = <1>;
ranges;
adc: adc@f8007100 {
compatible = "xlnx,zynq-xadc-1.00.a";
reg = <0xf8007100 0x20>;
interrupts = <0 7 4>;
clocks = <&clkc 12>;
can0: can@e0008000 {
compatible = "xlnx,zynq-can-1.0";
status = "disabled";
clocks = <&clkc 19>, <&clkc 36>;
clock-names = "can_clk", "pclk";
reg = <0xe0008000 0x1000>;
interrupts = <0 28 4>;
tx-fifo-depth = <0x40>;
rx-fifo-depth = <0x40>;
can1: can@e0009000 {
clocks = <&clkc 20>, <&clkc 37>;
reg = <0xe0009000 0x1000>;
interrupts = <0 51 4>;
gpio0: gpio@e000a000 {
compatible = "xlnx,zynq-gpio-1.0";
#gpio-cells = <2>;
#interrupt-cells = <2>;
clocks = <&clkc 42>;
gpio-controller;
interrupt-controller;
interrupts = <0 20 4>;
reg = <0xe000a000 0x1000>;
i2c0: i2c@e0004000 {
compatible = "cdns,i2c-r1p10";
clocks = <&clkc 38>;
interrupts = <0 25 4>;
reg = <0xe0004000 0x1000>;
#size-cells = <0>;
i2c1: i2c@e0005000 {
clocks = <&clkc 39>;
interrupts = <0 48 4>;
reg = <0xe0005000 0x1000>;
#size-cells = <0>;
intc: interrupt-controller@f8f01000 {
compatible = "arm,cortex-a9-gic";
#interrupt-cells = <3>;
reg = <0xF8F01000 0x1000>,
<0xF8F00100 0x100>;
L2: cache-controller@f8f02000 {
compatible = "arm,pl310-cache";
reg = <0xF8F02000 0x1000>;
interrupts = <0 2 4>;
arm,data-latency = <3 2 2>;
arm,tag-latency = <2 2 2>;
cache-unified;
cache-level = <2>;
mc: memory-controller@f8006000 {
compatible = "xlnx,zynq-ddrc-a05";
reg = <0xf8006000 0x1000>;
ocmc: ocmc@f800c000 {
compatible = "xlnx,zynq-ocmc-1.0";
interrupts = <0 3 4>;
reg = <0xf800c000 0x1000>;
uart0: serial@e0000000 {
compatible = "xlnx,xuartps", "cdns,uart-r1p8";
clocks = <&clkc 23>, <&clkc 40>;
clock-names = "uart_clk", "pclk";
reg = <0xE0000000 0x1000>;
interrupts = <0 27 4>;
uart1: serial@e0001000 {
clocks = <&clkc 24>, <&clkc 41>;
reg = <0xE0001000 0x1000>;
interrupts = <0 50 4>;
spi0: spi@e0006000 {
compatible = "xlnx,zynq-spi-r1p6";
reg = <0xe0006000 0x1000>;
interrupts = <0 26 4>;
clocks = <&clkc 25>, <&clkc 34>;
clock-names = "ref_clk", "pclk";
#size-cells = <0>;
spi1: spi@e0007000 {
reg = <0xe0007000 0x1000>;
interrupts = <0 49 4>;
clocks = <&clkc 26>, <&clkc 35>;
#size-cells = <0>;
qspi: spi@e000d000 {
clocks = <&clkc 10>, <&clkc 43>;
compatible = "xlnx,zynq-qspi-1.0";
interrupts = <0 19 4>;
reg = <0xe000d000 0x1000>;
#size-cells = <0>;
smcc: memory-controller@e000e000 {
#size-cells = <1>;
clock-names = "memclk", "aclk";
clocks = <&clkc 11>, <&clkc 44>;
compatible = "arm,pl353-smc-r2p1";
interrupts = <0 18 4>;
ranges ;
reg = <0xe000e000 0x1000>;
nand0: flash@e1000000 {
compatible = "arm,pl353-nand-r2p1";
reg = <0xe1000000 0x1000000>;
#address-cells = <0x1>;
#size-cells = <0x1>;
nor0: flash@e2000000 {
compatible = "cfi-flash";
reg = <0xe2000000 0x2000000>;
#size-cells = <1>;
gem0: ethernet@e000b000 {
compatible = "cdns,zynq-gem", "cdns,gem";
reg = <0xe000b000 0x1000>;
interrupts = <0 22 4>;
clocks = <&clkc 30>, <&clkc 30>, <&clkc 13>;
clock-names = "pclk", "hclk", "tx_clk";
#size-cells = <0>;
gem1: ethernet@e000c000 {
reg = <0xe000c000 0x1000>;
interrupts = <0 45 4>;
clocks = <&clkc 31>, <&clkc 31>, <&clkc 14>;
#size-cells = <0>;
sdhci0: sdhci@e0100000 {
compatible = "arasan,sdhci-8.9a";
clock-names = "clk_xin", "clk_ahb";
clocks = <&clkc 21>, <&clkc 32>;
interrupts = <0 24 4>;
reg = <0xe0100000 0x1000>;
broken-adma2;
sdhci1: sdhci@e0101000 {
clocks = <&clkc 22>, <&clkc 33>;
interrupts = <0 47 4>;
reg = <0xe0101000 0x1000>;
broken-adma2;
slcr: slcr@f8000000 {
#size-cells = <1>;
compatible = "xlnx,zynq-slcr", "syscon", "simple-mfd";
reg = <0xF8000000 0x1000>;
ranges;
clkc: clkc@100 {
#clock-cells = <1>;
compatible = "xlnx,ps7-clkc";
fclk-enable = <0xf>;
clock-output-names = "armpll", "ddrpll", "iopll", "cpu_6or4x",
"cpu_3or2x", "cpu_2x", "cpu_1x", "ddr2x", "ddr3x",
"dci", "lqspi", "smc", "pcap", "gem0", "gem1",
"fclk0", "fclk1", "fclk2", "fclk3", "can0", "can1",
"sdio0", "sdio1", "uart0", "uart1", "spi0", "spi1",
"dma", "usb0_aper", "usb1_aper", "gem0_aper",
"gem1_aper", "sdio0_aper", "sdio1_aper",
"spi0_aper", "spi1_aper", "can0_aper", "can1_aper",
"i2c0_aper", "i2c1_aper", "uart0_aper", "uart1_aper",
"gpio_aper", "lqspi_aper", "smc_aper", "swdt",
"dbg_trc", "dbg_apb";
reg = <0x100 0x100>;
rstc: rstc@200 {
compatible = "xlnx,zynq-reset";
reg = <0x200 0x48>;
#reset-cells = <1>;
syscon = <&slcr>;
pinctrl0: pinctrl@700 {
compatible = "xlnx,pinctrl-zynq";
reg = <0x700 0x200>;
syscon = <&slcr>;
dmac_s: dmac@f8003000 {
compatible = "arm,pl330", "arm,primecell";
reg = <0xf8003000 0x1000>;
interrupt-names = "abort", "dma0", "dma1", "dma2", "dma3",
"dma4", "dma5", "dma6", "dma7";
interrupts = <0 13 4>,
<0 14 4>, <0 15 4>,
<0 16 4>, <0 17 4>,
<0 40 4>, <0 41 4>,
<0 42 4>, <0 43 4>;
#dma-cells = <1>;
#dma-channels = <8>;
#dma-requests = <4>;
clocks = <&clkc 27>;
clock-names = "apb_pclk";
devcfg: devcfg@f8007000 {
clock-names = "ref_clk", "fclk0", "fclk1", "fclk2", "fclk3";
clocks = <&clkc 12>, <&clkc 15>, <&clkc 16>, <&clkc 17>, <&clkc 18>;
compatible = "xlnx,zynq-devcfg-1.0";
interrupts = <0 8 4>;
reg = <0xf8007000 0x100>;
syscon = <&slcr>;
efuse: efuse@f800d000 {
compatible = "xlnx,zynq-efuse";
reg = <0xf800d000 0x20>;
global_timer: timer@f8f00200 {
compatible = "arm,cortex-a9-global-timer";
reg = <0xf8f00200 0x20>;
interrupts = <1 11 0x301>;
clocks = <&clkc 4>;
ttc0: timer@f8001000 {
interrupts = <0 10 4>, <0 11 4>, <0 12 4>;
compatible = "cdns,ttc";
clocks = <&clkc 6>;
reg = <0xF8001000 0x1000>;
ttc1: timer@f8002000 {
interrupts = <0 37 4>, <0 38 4>, <0 39 4>;
clocks = <&clkc 6>;
reg = <0xF8002000 0x1000>;
scutimer: timer@f8f00600 {
interrupts = <1 13 0x301>;
compatible = "arm,cortex-a9-twd-timer";
reg = <0xf8f00600 0x20>;
clocks = <&clkc 4>;
usb0: usb@e0002000 {
compatible = "xlnx,zynq-usb-2.20a", "chipidea,usb2";
clocks = <&clkc 28>;
interrupts = <0 21 4>;
reg = <0xe0002000 0x1000>;
phy_type = "ulpi";
usb1: usb@e0003000 {
clocks = <&clkc 29>;
interrupts = <0 44 4>;
reg = <0xe0003000 0x1000>;
phy_type = "ulpi";
watchdog0: watchdog@f8005000 {
clocks = <&clkc 45>;
compatible = "cdns,wdt-r1p2";
interrupts = <0 9 1>;
reg = <0xf8005000 0x1000>;
timeout-sec = <10>;
pcw.dtsi
 * CAUTION: This file is automatically generated by Xilinx.
 * Version: HSI 2016.3
 * Today is: Fri Jan 27 09:52:29 2017
	cpus {
		cpu@0 {
			operating-points = <666666 1000000 333333 1000000>;
&gem0 {
	enet-reset = <&gpio0 50 0>;
	phy-mode = "rgmii-id";
	status = "okay";
	xlnx,ptp-enet-clock = <0x69f6bcb>;
&gpio0 {
	emio-gpio-width = <64>;
	gpio-mask-high = <0x0>;
	gpio-mask-low = <0x5600>;
&i2c0 {
	clock-frequency = <400000>;
	status = "okay";
&intc {
	num_cpus = <2>;
	num_interrupts = <96>;
&qspi {
	is-dual = <0>;
	num-cs = <1>;
	status = "okay";
&sdhci0 {
	status = "okay";
	xlnx,has-cd = <0x1>;
	xlnx,has-power = <0x0>;
	xlnx,has-wp = <0x0>;
&uart0 {
	current-speed = <115200>;
	device_type = "serial";
	port-number = <3>;
	status = "okay";
&uart1 {
	port-number = <0>;
	status = "okay";
&usb0 {
	dr_mode = "peripheral";
	phy_type = "ulpi";
	status = "okay";
	usb-reset = <&gpio0 51 0>;
&clkc {
	fclk-enable = <0x3>;
	ps-clk-frequency = <33333333>;
