Anonymous
Not applicable
Petalinux 2016.3 petalinux-build failure (Spansion NAND)
I hope my question is easily resolved. I am unsure what I am doing incorrect. I am attempting to place a linux build onto our board and the petalinux-build command is failing.
I have:
- Developed the Vivado project and exported the bit file
- done the petalinux-config command (which if I understand builds the device tree files)
- I then go and configure the kernel with the petalinux-config -c kernel command
- I didn't think I needed to change anything and kept defaults
- after wards I use the petalinux-build command and the command errors out giving me
 [ERROR] make[4]: *** [drivers/mtd/nand/nand.o] Error 1
 [ERROR] make[3]: *** [drivers/mtd/nand] Error 2
 [ERROR] make[2]: *** [sub-make] Error 2
 [ERROR] make[1]: *** [/home/<petalinux project>/build/linux/u-boot/u-boot-plnx/u-boot] Error 2
 ERROR: Failed to build linux
Any help would be appreciated.
Anonymous
Not applicable
Well, I really don't know if I fixed my problem all the way. At least I got the petalinux build to complete. according to:
AR# 60241
It looks like there is an issue with the u-boot header file. (I saw this earlier, but I was like surely this is several revisions past 13.10 and they have incorporated all their answer records into the newer revisions)
I simply added the
#define CONFIG_SYS_NAND_SELF_INIT 1
to my platform-auto.h file located in
<Petalinux Project>/subsystems/linux/configs/u-boot/
where I placed my #define (line 64)
#define CONFIG_SYS_NAND_ONFI_DETECTION
#define CONFIG_MTD_DEVICE
htsvn
hi,
would that be possible to share the hdf for further debug?
--hs
Anonymous
Not applicable
Here ya go.
I forgot to add TTC0 to the Vivado block diagram. I updated the block diagram and then exported the .hdf went back into petalinux and then did the command
$ petalinux-config --get-hw-description -p ../<path to petalinux project>
I get the error
ERROR: Partition "dtb" for image "dtb" is not in flash partition table in the subsystem configuration file.
ERROR: Please select "manual" if your flash partition of your image is outside the flash partition table set in the subsystem configuration file.
make: *** [post-config-auto-config] error 255
ERROR: failed to post config linux
ERROR: failed to config subsystem linux.
Anonymous
Not applicable
AR# 60241
I simply added the
shabbirk
Are you now able to access spansion nand flash device from both uboot and kernel?
Best Regards
Shabbir
Anonymous
Not applicable
Only U-boot, kernel does not boot
derekparks
Were you able to solve the issue?   I too am unable to connect to Spansion Nand via Linux.  U-boot is working just fine as Linux is stored and booted from nand.
Using zynq-7100, Linux 4.9.0, Spansion S34ML02G1, built via Petalinux 2017.2,
Here are errors from kernel:
root@xilinx-zc706-2017_2:~# dmesg|grep nand
pl35x_nand_cmd_function timed out
nand: No NAND device found
pl35x-nand e1000000.flash: nand_scan_ident for NAND failed
Here is my dts:
	memory-controller@e000e000 {
			#address-cells = <0x1>;
			#size-cells = <0x1>;
			status = "okay";
			clock-names = "memclk", "aclk";
			clocks = <0x1 0xb 0x1 0x2c>;
			compatible = "arm,pl353-smc-r2p1";
			interrupt-parent = <0x4>;
			interrupts = <0x0 0x12 0x4>;
			ranges;
			reg = <0xe000e000 0x1000>;
			arm,addr25 = <0x0>;
			arm,nor-chip-sel0 = <0x0>;
			arm,nor-chip-sel1 = <0x0>;
			arm,sram-chip-sel0 = <0x0>;
			arm,sram-chip-sel1 = <0x0>;
			flash@e1000000 {
				status = "okay";
				compatible = "arm,pl353-nand-r2p1";
				reg = <0xe1000000 0x1000000>;
				arm,nand-cycle-t0 = <0x5>;
				arm,nand-cycle-t1 = <0x5>;
				arm,nand-cycle-t2 = <0x2>;
				arm,nand-cycle-t3 = <0x3>;
				arm,nand-cycle-t4 = <0x1>;
				arm,nand-cycle-t5 = <0x2>;
				arm,nand-cycle-t6 = <0x2>;
				partition@nand-fsbl {
					label = "nand-fsbl";
					reg = <0x0 0xe0000>;
				partition@nand-bitstream {
					label = "nand-bitstream";
					reg = <0xe0000 0x4000000>;
				partition@nand-ubootenv {
					label = "nand-ubootenv";
					reg = <0x40e0000 0x20000>;
				partition@nand-ubootbin {
					label = "nand-ubootbin";
					reg = <0x4100000 0x220000>;
				partition@nand-linux {
					label = "nand-linux";
					reg = <0x4320000 0x6400000>;
				partition@nand-config {
					label = "nand-config";
					reg = <0xa720000 0xa00000>;
			flash@e2000000 {
				status = "disabled";
				compatible = "cfi-flash";
				reg = <0xe2000000 0x2000000>;
