Petalinux 2016.4 Can't create folders through install -d
I am trying to append a few recipes in the meta-user layer.
In do_install_append() for these recipes I call for example
install -d ${D}${localstatedir}/temp
When I run
bitbake -e myrecipe
, I can see that the do_install() function is expanded correctly, and the folder is created in
build/tmp/work/cortexa9hf-neon-xilinx-linux-gnueabi/myrecipe/1.0-r0/image/var/temp
I do not see this directory in final image, i.e.
/build/tmp/work/plnx_arm-xilinx.... /petalinux-user-image/1.0-r0/rootfs
or in the directory structure when I am running the application on hardware.
Any ideas or things I can try will be helpful, feels like I am missing something simple.
I think what is happening is are you installing files into those directories? if not it might not be included in the package:
See this thread:
https://lists.yoctoproject.org/pipermail/yocto/2015-February/023529.html
From the thread. try adding:
FILES_${PN} += ${localstatedir}/temp
I don't know why your technique isn't working, and I will be interested to read an explanation. In case you're interested in a simple technique that works for me, I created a custom application and followed the procedure described in the "Application Auto Run at Startup" section of UG1144, PetaLinux Tools Documentation Reference Guide. Then my startup script would have a line like:
mkdir /var/temp
See this thread:
Yes was exactly that. Thanks.
