Petalinux 2016.4 - Compile / clean behaviour
Petalinux behaves strangely in terms of keeping track of when source files change.
Let's say I have an app ... the only way I've found to consistently get the package to update with my changes is to:
petalinux-build -c <myapp> -x do_clean
petalinux-build -x mrproper
petalinux-build
Is there an easier/better way for it to pick up your source changes? I'd love to just be able to build my apps / modules individually and get them into the final image.ub file ...
Any tips?
I have similar inconsistency with respect to petalinux-build and found some success with removing the bitbake timestamp for tasks.  I also speed up my development by copying the application to my host filesystem in the do_install so i can copy it directly to the board rather than waiting for a new image to build then having to reinstall and reboot.
Example from /[project root dir]/project-spec/meta-user/recipes-apps/myapp/myapp.bb
# This file is the myapp recipe.
SUMMARY = "Simple myapp application"
SECTION = "PETALINUX/apps"
LICENSE = "MIT"
LIC_FILES_CHKSUM = "file://${COMMON_LICENSE_DIR}/MIT;md5=0835ade698e0bcf8506ecda2f7b4f302"
SRC_URI = "file://myapp.cpp \
  file://myapp.h \
  file://Makefile \
S = "${WORKDIR}"
do_compile[nostamp] = "1"
do_build[nostamp] = "1"
do_install[nostamp] = "1"
do_compile() {
  oe_runmake
do_install() {
  cp -f myapp /home/builduser/
  install -d ${D}${bindir}
  install -m 0755 myapp ${D}${bindir}
addendum....
With the nostamp lines in the bitbake recipe, i can use 'petalinux-build -c myapp' to recompile without cleaning or running petalinux-build.
