Petalinux 2016.4 Remote u-boot
Has anyone tried to use u-boot remote? I tried using an older u-boot version from github by specifying the url and tag but ran into issues with recipes already in the petalinux tools folder.
Re: Petalinux 2016.4 Remote u-boot
If you want to try to use other versions of u-boot, make sure to have following contents properly, which is according to your u-boot, (components/yocto/source/aarch64/layers/meta-xilinx/recipes-bsp/u-boot/u-boot-xlnx_2016.07.bb)
include u-boot-xlnx.inc
# this matches u-boot-xlnx 'xilinx-v2016.4' release tag
SRCREV = "0b94ce5ed4a6c2cd0fec7b8337e776b03e387347"
PV = "v2016.07${XILINX_EXTENSION}+git${SRCPV}"
FILESEXTRAPATHS_prepend := "${THISDIR}/u-boot-xlnx:"
SRC_URI_append_kc705-microblazeel = " file://microblaze-kc705-Convert-microblaze-generic-to-k.patch"
LIC_FILES_CHKSUM = "file://README;beginline=1;endline=6;md5=157ab8408beab40cd8ce1dc69f702a6c"
UBOOT_ENV_zc702-zynq7 = "uEnv"
UBOOT_ENV_zedboard-zynq7 = "uEnv"
SRC_URI_append_zc702-zynq7 = " file://uEnv.txt"
SRC_URI_append_zedboard-zynq7 = " file://uEnv.txt"
Best Regards
Shabbir
Do you mean a different u-boot repository that is not xilinx's?  If yes, then I use a private repo for u-boot(and the kernel) and created my own recipes in my bsp layer.
jeff
Hi @gavenant
Do you mean that you added recipes to the default configuration kernel and the modified the source to use remote repository? Can you post you error log?
Ibai
Ibai
 I was trying to use the remote URL option in the petalinux-config, pointing to Xilinx's repos but to a different tag. There was a few features that changed from the previous version of U-boot that I just want to test against my current project setup (the I2C stopped detecting the bus between versions 2016.1 and 2016.7 of u-boot) .
I made a mistake with the URL and fixed that - it downloaded the appropriate u-boot tag correctly. I just have to figure out what changed in the U-boot configs since I couldn't just do a drop in replacement.
Best Regards
Shabbir
Thanks, will do.
