Petalinux 2016.4 config cannot source bitbake
This is regarding Petalinux 2016.4.
I am unable to successfully run petalinux-config due to a bitbake error.
$ petalinux-create -t project -n emc2dp --template zynq
$ cd emc2dp
$ petalinux-config --get-hw-description=~/sdsoc-workspace/emc2dp/
INFO: Getting hardware description...
[INFO] generating Kconfig for project
[INFO] menuconfig project
/home/ananya/2016.3/emc2dp/petalinux/emc2dp/build/misc/config/Kconfig.syshw:30:warning: defaults for choice values not supported
/home/ananya/2016.3/emc2dp/petalinux/emc2dp/build/misc/config/Kconfig:546:warning: config symbol defined without type
*** End of the configuration.
*** Execute 'make' to start the build or try 'make help'.
[INFO] sourcing bitbake
ERROR: Failed to source bitbake
ERROR: Failed to config project.
ERROR: Get hw description Failed!.
Any idea what is happening? Am I missing bitbake? Bitbake is not listed as a dependency while installing Petalinux.
Best regards,
Ananya
I solved the problem. The environment setup file for yocto "components/yocto/source/aarch64/environment-setup-aarch64-xilinx-linux" uses absolute paths. These were no longer valid because I moved all installed files to a new directory.
Best regards,
Ananya
You should use a better name of folder for the 2016.4 project!
these 2 warnings seem to be a bug in petalinux 2016.4, I have also seen them
/home/ananya/2016.3/emc2dp/petalinux/emc2dp/build/misc/config/Kconfig.syshw:30:warning: defaults for choice values not supported /home/ananya/2016.3/emc2dp/petalinux/emc2dp/build/misc/config/Kconfig:546:warning: config symbol defined without type
The steps are already provided in the Petalinux User Guide:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug1144-petalinux-tools-reference-guide.pdf
Chapter-2, page -81
Debraj
How to set up Yoct e-SDK for Ubuntu16.04?
when I run petalinux 2017.1,I also met this problem,and I can't solve this problem,could you tell me what should I do.
I solved the problem with switching from python 3 to python 2.
I recieve this same error in Petalinux 2019.1
Segmentation fault (core dumped)
ERROR: Failed to menu config project component
and the config.log says:
INFO: [Hsi 55-1698] elapsed time for repository loading 0 seconds
hsi::open_hw_design: Time (s): cpu = 00:00:23 ; elapsed = 00:00:24 . Memory (MB): peak = 842.402 ; gain = 218.863 ; free physical = 117 ; free virtual = 4552
/home/aj/Desktop/Petalinux_Projects/petalinux_img/build/misc/config/Kconfig.syshw:29:warning: defaults for choice values not supported
/home/aj/Desktop/Petalinux_Projects/petalinux_img/build/misc/config/Kconfig:673:warning: config symbol defined without type
 My issue is not solved with changing the paths in yocto enivronnment either because I did not change the installation location.
What is the solution for this?
Thanks. 2018.1 has the same issue.
