peter.kuchnio
Petalinux 2016.4 /dev/flash
Hello, we are in the process of migrating from Petalinux 2016.1 to 2016.4
We are using QSPI flash to store our boot and kernel images. I see all of the mtd devices in /dev (e.g. mtdblock0 and so on).
In 2016.1, we also had a /dev/flash device present. This let us access flash partitions by the partition name (e.g. /dev/flash/boot, /dev/flash/kernel, etc.)
In 2016.4 I no longer see /dev/flash
How do I re-enable it? I need this for my firmware upgrade tool.
peter.kuchnio
In the short term I just used the mtdX devices directly with my firmware upgrade tools. This does work.
I just got this answer from Xilinx support. It seems the /dev/flash directory is just a bunch of symlinks. Its somewhat confusing to have 'fake' drivers in /dev in my opinion, but whatever.
#!/bin/sh
[ ! -f /proc/mtd ] && echo "/proc/mtd doesn't exist. Will not create /dev/flash/* device nodes" && exit 0
# process mtd entries in /proc, and create symlinks in /dev/flash
echo "Creating /dev/flash/* device nodes"
mkdir -p /dev/flash
rm -f /dev/flash/*
while read line; do
        dev=${line/:*/}
        # skip header line of /proc/mtd
        [ "${dev}" == "dev" ] && continue
        # Extract the partition name, wish there was a one-liner for this
        link=${line##* \"}
        link=${link%%\"}
        # cp -l on devnodes clones the node, not the contents
        # this is what we want
        cp -l /dev/${dev} "/dev/flash/${link}"
done < /proc/mtd
peter.kuchnio
#!/bin/sh
mkdir -p /dev/flash
rm -f /dev/flash/*
while read line; do
        dev=${line/:*/}
        link=${line##* \"}
        link=${link%%\"}
done < /proc/mtd
