peterjo
Petalinux 2017.1 - libgcc_s.so.1
In Petalinux 2017.1: How do I include libgcc_s.so.1 in rootfs?
bitblit11
I would really like to see an answer to this question too.  I found posts that indicate this was an option at least in Petalinux 2014, in an "Advanced" options menu in petalinux-config -c rootfs.  I can't find it in 2017.
shabbirk
Here are the steps to Include Prebuilt Modules/libraries in rootfs:
1.  petalinux-create -t apps --template install --name mymodule --enable
2.  cd project-spec/meta-user/recipes-apps/mymodule/files
3. copy the library file (*.so) here
4.  Edit mymodule.bb file, the file should look like the following:
SRC_URI = "file://library.so \ "
inherit module-base
S = "${WORKDIR}"
do_install() {
install -d ${D}${base_libdir}/modules/${KERNEL_VERSION}/extra
install -m 0755 ${S}/library.so ${D}/${base_libdir}/modules/${KERNEL_VERSION}/extra/
FILES_${PN} = "${base_libdir}/modules/"
5. Run petalinux-build
mgillott
Thanks this is exactly what I need. One question
where do I find a version of libgcc_s.so.1 precompiled for the Zynq ?
Malcolm
