trimble_pome
Petalinux 2017.1 - libstdc++.so.6 and other parts of the tools chain base
In Petalinux 2017.1: How do I include the base runtime libraries that in previous versions where in Filesystem Packages->base->external-xilinx-toolchain. Another thread suggested Filesystem Packages->base->gcc-runtime-xilinx, but in the 2017.1 version they do not appear to be there either.
Where are they now ?
ibaie
Hi @trimble_pome
If not wrong in petalinux 2017.1 it is located under miscellaneous folder (as in 2016.4)
Ibai
ibaie
Hi @trimble_pome
Ibai
rsgrimes
Where are these for Petalinux 2017.4?
zwilcox
This is kind of an old post. But this where I found it:
Under petalinux-config -c rootfs
FileSystem Packages  >  misc > gcc_runtime
