06-12-2017 02:57 AM
I am trying too boot my ZCU102 with a static IP, so that i can start the NFS configuration on it. I tried the following steps:
1. petalinux-create -t project -s zip/xilinx-zcu102-zu9-es2-rev1.0-v2017.1-final.bsp --name testproj
2. petalinux-config
> -*- Subsystem AUTO Hardware Settings ---> Ethernet Settings --->
[ ] Obtain IP address automatically
(192.168.69.2) Static IP address
(255.255.255.0) Static IP netmask
(192.168.69.1) Static IP gateway
> Exit > Save Changes
3. petalinux-build
4. petalinux-package --boot --fsbl images/linux/zynqmp_fsbl.elf --fpga images/linux/design_1_wrapper.bit --pmufw images/linux/pmufw.elf --u-boot
My Workstation already has an Ethernet interface at 192.168.69.1 When i copy over the BOOT.BIN and image.ub to the SDCARD and boot, the ifconfig on the board gives me this:
root@plnx_aarch64:~# ifconfig eth0 Link encap:Ethernet HWaddr 00:0A:35:00:22:01 inet6 addr: fe80::20a:35ff:fe00:2201%4879704/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:690 errors:0 dropped:1 overruns:0 frame:0 TX packets:9 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:118478 (115.7 KiB) TX bytes:1534 (1.4 KiB) Interrupt:31 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1%4879704/128 Scope:Host UP LOOPBACK RUNNING MTU:65536 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
If i then manually set up the eth0 interface as follows:
ifconfig eth0 192.168.69.2 netmask 255.255.255.0 route add default gw 192.168.69.1 eth0
I can ping my Workstation from the board and back.
After this, if i go back to the project folder and do a petalinux-config, it still shows the options as i left them, with the IP address configuration set to manual with the manual IP subnet and gateway.
How do I make sure that the configuration i set in the petalinux-config actually takes effect?
I need to be able to set the static ethernet IP address in order to use the NFS!!!
Board: ZCU102-ES2
Petalinux: 2017.1
Vivado: 2017.1
SDK: 2017.1
BSP: 2017.1
06-12-2017 09:41 PM
Hello @akkudub,
please see
https://forums.xilinx.com/t5/Embedded-Linux/Ethernet-IP-address-Petalinux-2017-1/m-p/765593#M19758
It should help.
06-12-2017 09:41 PM
Hello @akkudub,
please see
It should help.
06-13-2017 09:16 AM
If you want to set the static IP in petalinux 2017.1, here is the veified steps posted in this link along with attached recipe file:
https://forums.xilinx.com/t5/Embedded-Linux/No-static-IP-in-PetaLinux-2016-4/td-p/743272
Best Regards
Shabbir
06-13-2017 11:57 PM
06-13-2017 11:58 PM
06-14-2017 12:14 AM
Thanks for the update.
Can you please accept this as a solution, so that this will help others.
Best Regards
Shabbir
