Observer hardik123
Petalinux 2017.2 Cross Compiling
we installed peta linux sdk 2017_2.0 on ubuntu 14.04 platform  and successfully  booted kernel  from scratch image on zynq zc702 but now i want to execute an application program on zynq zc702 board through peta linux sdk so application is generated but when i am compiling by make ARCH =arm CROSS_COMPILER = arm-linux-gnueabihf or aarch64-linux-gnu-addr2line
aarch64-linux-gnu-ar
aarch64-linux-gnu-as
aarch64-linux-gnu-c++
aarch64-linux-gnu-c++filt
aarch64-linux-gnu-cpp
aarch64-linux-gnu-elfedit
aarch64-linux-gnu-g++
aarch64-linux-gnu-gcc
aarch64-linux-gnu-gcc-6.2.1
aarch64-linux-gnu-gcc-ar
aarch64-linux-gnu-gcc-nm
aarch64-linux-gnu-gcc-ranlib
aarch64-linux-gnu-gcov
aarch64-linux-gnu-gcov-tool
aarch64-linux-gnu-gdb
aarch64-linux-gnu-gprof
aarch64-linux-gnu-ld
aarch64-linux-gnu-ld.bfd
aarch64-linux-gnu-nm
aarch64-linux-gnu-objcopy
aarch64-linux-gnu-objdump
aarch64-linux-gnu-ranlib
aarch64-linux-gnu-readelf
aarch64-linux-gnu-size
aarch64-linux-gnu-strings
aarch64-linux-gnu-strip
but the out file is still able to give output in ubuntu itself but i am cross compiling for my target zynq board please give me helpful guidance and references as i am newbie to  peta linux environment please help.
Re: Petalinux 2017.2 Cross Compiling
why don't you compile your application inside petalinux itself?
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_2/ug1144-petalinux-tools-reference-guide.pdf
read at page 52
read at page 52
Newbie duanev
Maybe because petalinux-build takes minutes whereas gcc takes seconds? :)
Newbie nme31
I have the same problem.
I try to cross compil my libraries and applications outside petalinux but without succes, because I use libraries for multi target (windows, amd64, arm cortex,...).
Now, I try to compil for arm A53 (ultrascale) but when I compil, I have error messages like "stdio.h undefined".
I use aarch64-linux-gnu-gcc from /opt/Xilinx/SDK/2017.4/gnu/aarch64/lin/aarch64-linux/bin/.
Before run my Makefile, I do source "/opt/Xilinx/SDK/2017.4/settings64.sh".
Someone can help me ?
Does this apply for installing a new device library?
I have an Intel RealSense Camera that requires installing some libraries to be able to receive the frames from the camera. One way to do this is to cross compile the library source code to make it able to run on the ARM architecture.
Link to Library: https://github.com/IntelRealSense/librealsense
Newbie nme31
I have solved my problem with the help of this link : https://github.com/SDU-Embedded/linux_zynq/wiki/Cross-Compiling-for-the-Zynq-7000-Series-Platform
My probleme was that I passed the full path to the aarch64 gnu gcc and it is not necessary after apply the settings64.sh script.
