Petalinux 2017.2 build error do_deploy
NOTE: Executing RunQueue Tasks
ERROR: external-hdf-1.0-r0 do_deploy: Function failed: do_deploy (log file is located at /tmp/mbp_petalinux-2017.10.06-10.05.51/work/cortexa9hf-neon-xilinx-linux-gnueabi/external-hdf/1.0-r0/temp/log.do_deploy.32715)
ERROR: Logfile of failure stored in: /tmp/mbp_petalinux-2017.10.06-10.05.51/work/cortexa9hf-neon-xilinx-linux-gnueabi/external-hdf/1.0-r0/temp/log.do_deploy.32715
Log data follows:
| DEBUG: Executing python function sstate_task_prefunc
| DEBUG: Python function sstate_task_prefunc finished
| DEBUG: Executing shell function do_deploy
| install: cannot stat `/tmp/mbp_petalinux-2017.10.06-10.05.51/work/cortexa9hf-neon-xilinx-linux-gnueabi/external-hdf/1.0-r0/git/plnx_arm/system.hdf': No such file or directory
| WARNING: /tmp/mbp_petalinux-2017.10.06-10.05.51/work/cortexa9hf-neon-xilinx-linux-gnueabi/external-hdf/1.0-r0/temp/run.do_deploy.32715:1 exit 1 from 'install -m 0644 /tmp/mbp_petalinux-2017.10.06-10.05.51/work/cortexa9hf-neon-xilinx-linux-gnueabi/external-hdf/1.0-r0/git/plnx_arm/system.hdf /tmp/mbp_petalinux-2017.10.06-10.05.51/work/cortexa9hf-neon-xilinx-linux-gnueabi/external-hdf/1.0-r0/deploy-external-hdf/Xilinx-plnx_arm.hdf'
| ERROR: Function failed: do_deploy (log file is located at /tmp/mbp_petalinux-2017.10.06-10.05.51/work/cortexa9hf-neon-xilinx-linux-gnueabi/external-hdf/1.0-r0/temp/log.do_deploy.32715)
ERROR: Task (/home/e296015/dev_tools/opt/pkg/petalinux/components/yocto/source/arm/layers/meta-xilinx-tools/recipes-bsp/hdf/external-hdf.bb:do_deploy) failed with exit code '1'
The error correct as there is not system.hdf located there. My system.hdf is located in a exported sdk path
Using RHEL 6.9
It looks like do_deploy is doing this
do_deploy() {
install -d /tmp/mbp_petalinux-2017.10.06-10.05.51/work/cortexa9hf-neon-xilinx-linux-gnueabi/external-hdf/1.0-r0/deploy-external-hdf
if [ "git://" = "git://" ]; then
else
install -m 0644 /tmp/mbp_petalinux-2017.10.06-10.05.51/work/cortexa9hf-neon-xilinx-linux-gnueabi/external-hdf/1.0-r0/github.com/Xilinx/hdf-examples.git /tmp/mbp_petalinux-2017.10.06-10.05.51/work/cortexa9hf-neon-xilinx-linux-gnueabi/external-hdf/1.0-r0/deploy-external-hdf/Xilinx-plnx_arm.hdf
fi
So is the build process not putting the file there? I suppose I can circumvent this by copying my system.hdf to that location or modifying the run.do_deploy script
Are you using petalinux-config --get-hw-description=<path to hdf>
By default yocto will use the external-hdf if this isn't used
For some reason I couldn't do it from outside of the directory where the hdf was located, so I called petalinux-config from the same directory as the hdf
