Participant thburghout
Petalinux 2017.2 creating header only library
For kernel/user-space communication as described in the sheets about "Linux DMA from User-Space" (Xilinx, 2014) I need to create a header only library with the definition of the struct used for communicating.
I created a new C apps, removed the Makefile and source file and created a header file with the struct definition. How would I go about including this in a module and another application?
I'm assuming I need to adjust the bb files, but I have no idea what I should adjust to create the dependency and assure the correct include parameters during the boot process (since the files are built in another directory).
I think this question is similar to https://forums.xilinx.com/t5/Embedded-Linux/Just-getting-started-with-Petalinux-2017-2-need-more/td-p/780793/page/2 . But the link provided by sandeepg only helps me slightly.
I added
PROVIDES = "libdma-channel-if"
to the bb file of the header only library.
How would I go about "requiring" this during module compilation? Such that I can use
#include <libdma-channel-if/libdma-channel-if.h>
Thanks!
Re: Petalinux 2017.2 creating header only library
you can refer some example here
https://github.com/BarrelfishOS/barrelfish
Thanks and Regards
Balkrishan
I don't need the header file to be present in the image. Just to be included during compilation.
