[Petalinux 2017.2 for Zynq-7000] petalinux-build Failed if project has more than 16 interrupts
My project based on Zynq-7000 (xc7z045) and petalinux 2017.2, must have more than 16 interrupts from PL side to PS, which are not fit for PS-GIC. The interrupts are mainly from VDMA s2mm_introut/mm2s_introut
From the stand-alone project I can cascade with axi-interrupt-controller as mentioned in the guide:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842020/Cascade+Interrupt+Controller+support+in+DTG
However, when I porting to build with petalinux, the petalinux gives error "s2mm_introut is not connected". I had try some ways such as:
- Apply patch https://www.xilinx.com/support/answers/68963.html
- Merge VDMA interrupt signal s2mm_introut/mm2s_introut by an OR ligic ultil
It quite strange that only VDMA interrupts have this issue, others (axi-uart, axi-i2c) is not. I start to think xilinx does not support VDMA with axi-interrupt-controller cascade zynq GIC ?
Anyone has solved this issue? please recommend me the way to pass it?
Thank you so much. (kudos for help, of course )
Can you connect the axi_vdma interrupt to the concat, and the irq from the axi interrupt controller to the concat, and connect the dout of the concat to the PS irg_f2p
If you share your HDF/XSA then I can take a quick look
Hello Stephenm,
Thank you for your reply. I attached my hdf (zip file). The sample project with 2 axi iic, 1 vdma, axi interrupt controller.
Do you have any comments?
Hello Stephenm,
Do you have any ideas to solve my issue?
Thank you.
Thanks for your suggestion. I'll try and give feedback as soon as I come back to work.
You are right. If I do as you said It build all succeeded.
Next step, I will try to work with interrupt on Petalinux and check if it has any issues.
Thank you so much for your help.
Hello Stephenm,
Today when I try with more VDMA interrupt connect to concat of axi-interrupt controller, the warning appear "Interrupt pin "intr" of IP block: "CPU_axi_intc_0" is not connected to any interrupt controller" and the error follow.
I have no idea how to solve it. Please advice me.
Here are the log:
[INFO] building project
[INFO] sourcing bitbake
INFO: bitbake petalinux-user-image
Loading cache: 100% |###################################################################| Time: 0:00:00
Loaded 3239 entries from dependency cache.
Parsing recipes: 100% |#################################################################| Time: 0:00:01
Parsing of 2449 .bb files complete (2413 cached, 36 parsed). 3239 targets, 224 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Initialising tasks: 100% |##############################################################| Time: 0:00:05
Checking sstate mirror object availability: 100% |######################################| Time: 0:00:00
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: device-tree-generation-xilinx+gitAUTOINC+43551819a1-r0 do_configure: Function failed: do_configure (log file is located at /media/huyvq/FAST/WORK/CMR_TX/SRC/CMRTX_EVT_HW/SW/linux_cmrtx/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/device-tree-generation/xilinx+gitAUTOINC+43551819a1-r0/temp/log.do_configure.13478)
ERROR: Logfile of failure stored in: /media/huyvq/FAST/WORK/CMR_TX/SRC/CMRTX_EVT_HW/SW/linux_cmrtx/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/device-tree-generation/xilinx+gitAUTOINC+43551819a1-r0/temp/log.do_configure.13478
Log data follows:
| DEBUG: Executing python function sysroot_cleansstate
| DEBUG: Python function sysroot_cleansstate finished
| DEBUG: Executing shell function do_configure
| MISC_ARG is -yamlconf /media/huyvq/FAST/WORK/CMR_TX/SRC/CMRTX_EVT_HW/SW/linux_cmrtx/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/device-tree-generation/xilinx+gitAUTOINC+43551819a1-r0/device-tree-generation.yaml
| APP_ARG is -app "device-tree"
| cmd is: xsct /media/huyvq/FAST/WORK/CMR_TX/SRC/CMRTX_EVT_HW/SW/linux_cmrtx/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/device-tree-generation/xilinx+gitAUTOINC+43551819a1-r0/dtgen.tcl -ws /media/huyvq/FAST/WORK/CMR_TX/SRC/CMRTX_EVT_HW/SW/linux_cmrtx/build/../components/plnx_workspace -pname device-tree-generation -rp /media/huyvq/FAST/WORK/CMR_TX/SRC/CMRTX_EVT_HW/SW/linux_cmrtx/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/device-tree-generation/xilinx+gitAUTOINC+43551819a1-r0/git -processor ps7_cortexa9_0 -hdf /media/huyvq/FAST/WORK/CMR_TX/SRC/CMRTX_EVT_HW/SW/linux_cmrtx/build/tmp/deploy/images/plnx_arm/Xilinx-plnx_arm.hdf -arch 32 -app "device-tree" -yamlconf /media/huyvq/FAST/WORK/CMR_TX/SRC/CMRTX_EVT_HW/SW/linux_cmrtx/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/device-tree-generation/xilinx+gitAUTOINC+43551819a1-r0/device-tree-generation.yaml
| INFO: [Hsi 55-1698] elapsed time for repository loading 0 seconds
| WARNING: Interrupt pin "intr" of IP block: "CPU_axi_intc_0" is not connected to any interrupt controller
you are getting the warning:
Can you share the updated HDF?
