Scholar ronnywebers
Petalinux 2017.2 - questions about the dts & dtsi files
UG1144 (Petalinux ref guide) writes (page 75) that any customisations or additions to the device tree should be made in the file 'system-user.dtsi'. (located under /project-spec/meta-user/recipes-bsp/device-tree/files)
Then for my Zynq project, Petalinux generated a bunch of dts(i) files, which can be found under :
/components/plnx_workspace/device-tree-generation
starting with the top-level file 'system-top.dts'
looking into the file, this top level file includes :
- zynq-7000.dtsi
- pl.dtsi
- pcw.dtsi
- system-user.dtsi. (user overrides or additions)
Q1 : is it possible to see some kind of 'combined' result of the .dts file + 4 .dtsi files? I assume some pre-processor will parse these files into one -> can this result be seen somewhere?
i.e. : pcw.dtsi overrides (enables) uart1 with status = "okay"  (where it was "disabled" in zynq-7000.dtsi, which is lower in the dts hierarchy). So does some 'preprocessor of the 'DTB' tool generate a 'single, combined' dts file, so we can easier see the overall node properties?
Q2 : there are 3 files remaining, and I am wondering what there use is, as they don't seem to be included in the 'system-top.dts' file? :
- skeleton.dtsi
- system-conf.dtsi
- plnx_arm-system.dts
Re: Petalinux 2017.2 - questions about the dts & dtsi files
Hallo @ronnywebers,
Regarding Q1:
You can get the "combined version" exactly how you suggest. The only problem is that the references (like <&phy0>) will disappear and will be replaced by numbers.
#if you don't have it installed:
sudo apt-get install device-tree-compiler
dtc -I dts -O dtb system-top.dts -o system.dtb
dtc -I dtb -O dts system.dtb -o recover.dts
The "combined" file is recover.dts
Regarding Q2:
system-conf.dtsi is included in "plnx_arm-system.pp". It's generated by Petalinux, and apparently contains info of your hardware.
skeleton.dtsi is included in the kernel sources, but it's deprecated. Apparently, it is the minimum to boot.
Ignacio
Hallo @ronnywebers,
Regarding Q1:
Regarding Q2:
Ignacio
Scholar ronnywebers
ok - so it looks like these 3 files are not really used ...
thanks for the great tip about reverse compiling the device tree!
