Petalinux 2017.3 instalation don't found openssl library
Hello all,
i am trying to install the Petalinux 2017.3 on my CentOs7. I follow the instructions from:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_3/ug1144-petalinux-tools-reference-guide.pdf
However, when I try to install the Petalinux it detects a missing library. In particular it don't find the openssl library.
When I try to install the openssl library I found that it is already installed.
Any ideas?
baldrism
Re: Petalinux 2017.3 instalation don't found openssl library
Hi all,
Finally I solved the problem. As @rfs613 said it was due the missing openssl devel package.
The command to install it in the CentOs 7 is:
yum install openssl-devel
Thanks a lot,
baldrism
Just a wild guess: try installing the 32-bit version of openssl (you have the x86_64 bit version). The command is:
yum install openssl.i686
Note the ".i686" on the end.
Also, you might need the devel package, which would be "openssl-devel.i686"
Hi @baldrism,
Yes you need dev package. Refer 2017.3 PetaLinux release notes https://www.xilinx.com/support/answers/69952.html at the bottom you can find the spreadsheet https://www.xilinx.com/Attachment/2017.3-PetaLinux-Packages-List.xlsx
Sandeep
Hi @rfs613,
thanks for your answer. I tried your idea but however it doesn't find the library:
Hi all,
Thanks a lot,
baldrism
