Visitor asuarez
Petalinux 2017.4 AXI4-Lite FIFO Question
Hello everyone,
I am working with the zynq zc702 board and wanted to use the AXI4-Lite FIFO to communicate between the PL-PS as you can see in the image below.
In a C++ application, I am using /dev/mem and mmap to access the FIFO with two functions to read and write to specific register spaces.
// C++ CLASS FOR FIFO
uin32_t page_size = 0x10000;
int AxiFifo::initialize(void) { /* Open /dev/mem file */ fifo_fd = open ("/dev/mem", O_RDWR); if (fifo_fd < 0){ return -1; } /* mmap the device into memory */ page_addr = ( reg_addr & (~(page_size-1))); page_offset = reg_addr - page_addr; fifo_ptr = mmap(NULL, page_size, PROT_READ|PROT_WRITE, MAP_SHARED, fifo_fd, page_addr); if (fifo_ptr == nullptr){ return -1; } return 0; } uint32_t AxiFifo::readWord(int reg_space) {
return *((volatile unsigned long *)(fifo_ptr + page_offset + reg_space)); } void AxiFifo::writeWord(int reg_space, uint32_t data) {
*((volatile unsigned long *)(fifo_ptr + page_offset + reg_space)) = data; }
// IN MAIN()
AxiFifo rawFifo(0x43c00000);
    int ret = rawFifo.initialize();
    if(ret < 0){
        LOG(ERROR) << "raw fifo init failed";
        return -1;
rawFifo.writeWord(ISR, 0xFFFFFFFF);
rawFifo.readWord(ISR)
rawFifo.writeWord(IER, 0x0C000000);
rawFifo.writeWord(TDR, 0x00000002);
...etc
My issue is that the values I am reading don't seem to make any sense. The FIFO's receive occupancy never seems to increase even if I push values to it. Does anyone know what I am doing wrong?
Thank you,
Re: Petalinux 2017.4 AXI4-Lite FIFO Question
By "push values to it" do you mean send a packet to it via the AXI Stream interface, ending with TLAST?
