Petalinux 2017.4 busybox httpd cgi 404 not found
Hi, all.
I can't display my cgi file.
I can display my htm file.
What is wrong settings?
I put "test.cgi" to /srv/www/cgi-bin/.
And Access to this file on browser.
URL is http://192.168.1.162/cgi-bin/test.cgi(192.168.1.162 is my zc706 board IP address).
 But Browser display "404 Not Found".
"test.cgi" is below.
#!/bin/bash
echo "a"
httpd exec with option -h /srv/www.
When ps command exec, output is below.
 /usr/sbin/httpd -h /srv/www
/etc/httpd.conf didn't create.
Thank you.
Scholar rfs613
Re: Petalinux 2017.4 busybox httpd cgi 404 not found
There are several potential problems:
  1. There is no "bash", just the busybox shell.
  2. Script needs to output HTTP headers before the data.
  3. Script must be executable.
So give the following a try. Note the shell is "sh" rather than bash. Also, headers are being output, followed by a blank line, and then your data.
#!/bin/sh
echo -en "Content-type: text/html\r\n"
echo -en "\r\n"
echo "a"
Make sure your script is executable, and try running it as "/srv/www/cgi-bin/test.cgi"... make sure you see the output appearing. Then give it a try from your browser and you should see "a" appear.
Scholar rfs613
#!/bin/sh
echo -en "\r\n"
echo "a"
First, My cgi file has ^M code.
I erase '\r' to use below command.
$ sed -i 's/\r//' test.cgi
Second, Script needs to output HTTP headers before the data.
I add Scholar's code.
After two change,I can see "a" appear.
Thank you very much!
