Petalinux 2017.4 docker container
Im trying to setup petalinux in a docker container based on Ubuntu 16.04.
Im getting errors when running petalinux-env-check though.
developer@7a217c2e945b:~$ ./petalinux-env-check
INFO: Checking free disk space
INFO: Checking installed tools
./petalinux-env-check: line 252: [: =: unary operator expected
./petalinux-env-check: line 335: [: ==: unary operator expected
./petalinux-env-check: line 337: [: ==: unary operator expected
./petalinux-env-check: line 339: [: ==: unary operator expected
./petalinux-env-check: line 341: [: ==: unary operator expected
./petalinux-env-check: line 343: [: ==: unary operator expected
./petalinux-env-check: line 284: [: =: unary operator expected
INFO: Checking installed development libraries
./petalinux-env-check: line 425: [: ==: unary operator expected
INFO: Checking network and other services
I've installed all the dependencies listed in UG1144 and changed my shell to bash via dpkg-reconfigure.
The container is based on:
developer@7a217c2e945b:~$ uname -a
Linux 7a217c2e945b 4.10.0-42-generic #46~16.04.1-Ubuntu SMP Mon Dec 4 15:57:59 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
petalinux-env-check runs fine on my Ubuntu VM. It is a binary though and I don't know where the source for this is so I don't know what the script is doing.
Any thoughts? Thanks!
I get the same issue when executing settings.sh on my Gentoo workstation:
PetaLinux environment set to '/home/user/Xilinx/PetaLinux/2017.4'
environment: Zeile 252: [: =: Einstelliger (unärer) Operator erwartet.
environment: Zeile 335: [: ==: Einstelliger (unärer) Operator erwartet.
environment: Zeile 337: [: ==: Einstelliger (unärer) Operator erwartet.
environment: Zeile 339: [: ==: Einstelliger (unärer) Operator erwartet.
environment: Zeile 341: [: ==: Einstelliger (unärer) Operator erwartet.
environment: Zeile 343: [: ==: Einstelliger (unärer) Operator erwartet.
environment: Zeile 284: [: =: Einstelliger (unärer) Operator erwartet.
I tried to read the strace output of the ./petalinux-env-check but could not find the reason why these messages occur.
open("/usr/share/locale/locale.alias", O_RDONLY|O_CLOEXEC) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=2997, ...}) = 0
read(3, "# Locale name alias data base.\n#"..., 4096) = 2997
read(3, "", 4096) = 0
close(3) = 0
open("/usr/share/locale/de_DE.UTF-8/LC_MESSAGES/bash.mo", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/share/locale/de_DE.utf8/LC_MESSAGES/bash.mo", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/share/locale/de_DE/LC_MESSAGES/bash.mo", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/share/locale/de.UTF-8/LC_MESSAGES/bash.mo", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/share/locale/de.utf8/LC_MESSAGES/bash.mo", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/share/locale/de/LC_MESSAGES/bash.mo", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=94101, ...}) = 0
mmap(NULL, 94101, PROT_READ, MAP_PRIVATE, 3, 0) = 0x7fb4b69d8000
close(3) = 0
fstat(2, {st_mode=S_IFREG|0644, st_size=47716, ...}) = 0
write(2, "environment: Zeile 252: [: =: Ei"..., 72environment: Zeile 252: [: =: Einstelliger (unärer) Operator erwartet. ) = 72
stat(".", {st_mode=S_IFDIR|0711, st_size=4096, ...}) = 0
This is the first occurrence of the messages.
Copying petalinux-env-check out of the container and running strace -f ./petalinux-env-check shows this line:
execve("/usr/bin/lsb_release", ["lsb_release", "-i"], [/* 52 vars */]) = 0
Finding the package that install that binary:
$ dpkg-query -S /usr/bin/lsb_release
lsb-release: /usr/bin/lsb_release
Adding the installation of the package lsb-release to my Dockerfile fixed the problem for me.
installing the lsb-release fixed my problems also under Gentoo:
[I] sys-apps/lsb-release
     Verfügbare Versionen:   1.4 ~1.4-r1 ~1.4-r2 ~1.4-r3
     Installierte Versionen: 1.4(10:31:30 15.02.2018)
     Startseite:             https://wiki.linuxfoundation.org/lsb/
     Beschreibung:           LSB version query program
Thank you...
Where you ever able to successfully put Petalinux 2017.4 in a container?  I was able to get Petalinux 2017.1 into a container after some difficulty and I think my setup should work for Petalinux 2017.4 as well with some minor changes.
Here's my repo: https://github.com/JamesAnthonyLow/docker-xilinx-petalinux-desktop
I forked from queeno/docker-ubuntu-desktop in order to get a VNC server environment going so I could install the XSDK tools inside the container for Petalinux.
Tags (2)
