01-08-2019 11:04 PM - edited 01-09-2019 05:20 AM
Greetings,
I am currently trying to create a socket application that connects ZC702 Board to my Ubuntu 16.04 PC. I am able to ping to my PC from the board and reverse is valid also.
Firstly, I've tried both socket codes, which is taken from the above link, on PC. Codes are compiled on PC as " gcc xxx.c -o xxx " and both runs on different terminals. Result, codes work. Secondly, I've tried to apply client side of the code to Zynq device, compiled without any change and run on board. When I try to connect to server ( which is my PC ) I got " no route to host " but the interesting point is that I am still able to ping to PC's IP address which is also written on Client C Code. ( host = gethostbyname("PC's IP address"); )
Another interesting point is that, Zynq device connects to any client when it is the server. My application needs Zynq device to be client side.
Any suggestions or ideas would be appreciated.
Best Regards,
Ömer
01-09-2019 05:22 AM
01-09-2019 05:22 AM
01-10-2019 11:56 AM
Hi @omerce,
May be your Vivado project is not generated correctly. Try using Standard Petalinux BSP file for ZC702 board from Xilinx Download web page? The default BSP project will work for TCPIP connectivity and then try the Client & server application on top of it. To debug your Vivado project, is it generated correctly or not & Network connectivity is correct or not then simply try our Xapp1026 (https://www.xilinx.com/support/documentation/application_notes/xapp1026.pdf). Hope this will help.
01-11-2019 12:31 AM
Dear @jadhavs
Thank you for your kind reply and help. I already use Petalinux BSP file for ZC702 board and as I mentioned above I solved the problem via disabling Firewall.
Best Regards,
Ömer
