skaat27
Petalinux 2018.2 failed to source bitbake error
Hi All,
I've been trying to upgrade my project from 2016.4 to 2018.2 Petalinux. I always get the below error when i try to run  petalinux-config --get-hw-description command. I have tried to delete the project and start from scratch. Nothing seems to work. Any Suggestions?
[INFO] sourcing bitbake
ERROR: Failed to source bitbake
ERROR: Failed to config project.
ERROR: Get hw description Failed!.
skaat27
Looking at the config.log it says
NOTE: Starting bitbake server...
Specified layer directory doesn't contain a conf/layer.conf file
ERROR: Failed to add meta-plnx-generated layer
