kharalan
Petalinux 2018.2 on ZCU102 reboot problem
I'm having a problem with the reboot command on ZCU102 and Petalinux 2018.2.
The reboot command does not work every time. Some time it reboots the board, and some time it gets stuck like this:
root@ptlinux:~# reboot
Broadcast message from root@ptlinux (ttyPS0) (Thu Nov 1 23:27:17 20ÃJÒ
The system is going down for reboot NOW!
INIT: Sending processes the TERM signal
root@ptlinux:~# Stopping Dropbear SSH server: stopped /usr/sbin/dropbear (pid 2348)
dropbear.
Stopping syslogd/klogd: stopped syslogd (pid 2356)
stopped klogd (pid 2359)
done
Stopping tcf-agent: OK
Deconfiguring network interfaces... [10776.229208] macb ff0e0000.ethernet: gem-ptp-timer ptp clock unregistered.
done.
Sending all processes the TERM signal...
logout
[10777.004471] macb ff0e0000.ethernet eth0: link down
Sending all processes the KILL signal...
Unmounting remote filesystems...
Deactivating swap...
Unmounting local filesystems...
Rebooting... [10783.546706] reboot: Restarting system
Some time the reboot will work several times in a row, other times will not work and I need to press the POR button. I have not found any pattern. I need a reliable way to reboot the system when I load new FPGA or Linux image. Any suggestions?
Thanks!
gudishak
What is the boot mode SD or QSPI ?
Best Regards
Kranthi
kharalan
The boot mode is SD.
sandeepg
Hi @kharalan,
Have you connected with JTAG cable while rebooting?
Sandeep
kharalan
Yes - it looks like the reboot is not working after I connect with the JTAG to the FPGA. If I don't have the JTAG cable connected or do not open the HW manager in Vivado the reboot command works fine.
sandeepg
Hi @kharalan,
Yes this is a known issue refer this AR for work around https://www.xilinx.com/support/answers/69143.html
I would suggest to walk through release notes https://www.xilinx.com/support/answers/71201.html when you start build a project.
Sandeep
wangyudi
Hi  kharalan , I encountered the same problem. Did https://www.xilinx.com/support/answers/69143.html work for you?
