micki_b12
Petalinux 2018.2 update fstab how to
I would like to change the default mount point of partition
I tried
How to Auto Mount SD card in Yocto Recipes
meta-intel-edison
But when image.ub created it still take the default fstab without my changes
Created
project-spec/meta-user/recipes-core/base-files
File:
base-files_%.bbappend &
File content:
SRC_URI += "file://fstab"
do_install_append() {
install -m 0644 ${WORKDIR}/fstab ${D}${sysconfdir}/fstab
project-spec/meta-user/recipes-core/base-files/base-files
fstab
/dev/root / auto defaults 1 1
proc /proc proc defaults 0 0
devpts /dev/pts devpts mode=0620,gid=5 0 0
tmpfs /run tmpfs mode=0755,nodev,nosuid,strictatime 0 0
tmpfs /var/volatile tmpfs defaults 0 0
# uncomment this if your device has a SD/MMC/Transflash slot
#/dev/mmcblk0p1 /media/card auto defaults,sync,noauto 0 0
I would like to update SD mount point to this
#Re-Mount EMMC
/dev/mmcblk0p2 /run/media/mmcblk0p2 auto defaults,sync,noauto 0 0
/dev/mmcblk0p3 /run/media/mmcblk0p1 auto defaults,sync,noauto 0 0
/dev/mmcblk0p1 /run/media/mmcblk0p3 vfat dmask=000,fmask=0111,user 0 0
micki_b12
How to update udev black.list
/project-spec/meta-user/recipes-core/udev$
drwxr-xr-x 2 mbalanga mbalanga 4096 Oct 25 11:01 udev-extraconf
-rw-r--r-- 1 mbalanga mbalanga 99 Oct 25 11:10 udev-extraconf_%.bbappenda
And then
sed -i '$s|$|\n/dev/mmcblk0*|' ${D}${sysconfdir}/udev/mount.blacklist
/project-spec/meta-user/recipes-core/udev/udev-extraconf$ ls -l
-rw-r--r-- 1 mbalanga mbalanga 66 Oct 25 09:21 mount.blacklist
And It work
micki_b12
I tried
https://stackoverflow.com/questions/43283825/yocto-recipe-to-update-etc-fstab
Create a new layer using
yocto-layer create mylayer
inside it, create a folder called recipes-core and inside this folder create another folder called base-files.
Inside this folder create a file called base-files_%.bbappend, with the following content:
FILESEXTRAPATHS_append := "${THISDIR}/${PN}:"
Create another folder called base-files, inside which you should put a file called fstab with your configurations.
Also Tried
FILESEXTRAPATHS_prepend := "${THISDIR}/base-files:"
Tried also
FILESEXTRAPATHS_prepend := "${THISDIR}/files:"
Didn't work
patocarr
Hi @micki_b12
  You may try using a sed command in the .bbappend, as follows:
    sed -i '$|s|$|\n/dev/mmcblk0p2 /run/media/mmcblk0p2 auto defaults,sync,noauto 0 0\n
/dev/mmcblk0p3 /run/media/mmcblk0p1 auto defaults,sync,noauto 0 0\n
/dev/mmcblk0p1 /run/media/mmcblk0p3 vfat dmask=000,fmask=0111,user 0 0|g' ${D}${sysconfdir}/fstab
  The sed command matches the last line ($), then replaces it with the 3 lines that follow. The sed separator '|' is used to avoid conflict with the forward slashes '/'.
-Pat
Give kudos if helpful. Accept as solution if it solves your problem.
https://tuxengineering.com/blog
micki_b12
Thank for the reply I am miising something attach below the
PATH: project-spec/meta-user/recipes-core/base-file/base-files_%.bbappend
sed -i '$s$\n/dev/mmcblk0p2 /run/media/mmcblk0p2 auto defaults,sync,noauto 0 0\n /dev/mmcblk0p3 /run/media/mmcblk0p1 auto defaults,sync,noauto 0 0\n /dev/mmcblk0p1 /run/media/mmcblk0p3 vfat dmask=000,fmask=0111,user 0 0|g' ${D}${sysconfdir}/fstab
And I get this error
sed: -e expression #1, char 213: unterminated `s' command
patocarr
Hi @micki_b12
  Looks like you're missing the first "|" (i.e. pipe) separators?
-Pat
micki_b12
sed -i '$|s|$|\n/dev/mmcblk0p2 /run/media/mmcblk0p2 auto defaults,sync,noauto 0 0\n /dev/mmcblk0p3 /run/media/mmcblk0p1 auto defaults,sync,noauto 0 0\n /dev/mmcblk0p1 /run/media/mmcblk0p3 vfat dmask=000,fmask=0111,user 0 0|g' ${D}${sysconfdir}/fstab
sed: -e expression #1, char 2: unknown command: `|'
patocarr
Hi @micki_b12
  How about this:
    sed -i '$s|$|\n/dev/mmcblk0p2 /run/media/mmcblk0p2 auto defaults,sync,noauto 0 0\n
  I think I transcribed an extra "|" character in the sed expression.
-Pat
micki_b12
Thanks it worked and update the fstab
But the mount is the same attach /etc/fstab and mount output
It's seems both
/dev/mmcblk0p3 and  /dev/mmcblk0p1 are mounted to  /run/media/mmcblk0p1
patocarr
Hi @micki_b12
  I suspect the first space character is somehow affecting the line being taken. For example, the dmask on /dev/mmcblk0p1 is not being applied.
  Let's try removing the space after \n's, to avoid the leading whitespace.
    sed -i '$s|$|\n/dev/mmcblk0p2 /run/media/mmcblk0p2 auto defaults,sync,noauto 0 0\n/dev/mmcblk0p3 /run/media/mmcblk0p1 auto defaults,sync,noauto 0 0\n/dev/mmcblk0p1 /run/media/mmcblk0p3 vfat dmask=000,fmask=0111,user 0 0|g' ${D}${sysconfdir}/fstab
-Pat
micki_b12
Again Thanks For the help  didn't work
fstab
mtab
/dev/mmcblk0p1 /run/media/mmcblk0p1 vfat rw,relatime,gid=6,fmask=0007,dmask=0007,allow_utime=0020,codepage=437,iocharset=iso8859-1,s0
/dev/mmcblk0p3 /run/media/mmcblk0p3 ext4 rw,relatime,data=ordered 0 0
/dev/mmcblk0p2 /run/media/mmcblk0p2 ext4 rw,relatime,data=ordered 0 0
patocarr
Hi @micki_b12
  I suspect udev is interfering with the mounts and getting in front of fstab. I'm not familiar with udev, but there's a file in /etc/udev/mount_blacklist that you may patch to add the /dev/mmcblk*, so udev ignores the mmc mount and gives priority to fstab to do its thing.
  I'd try adding another sed command to the same script to patch it. Something like:
-Pat
micki_b12
Hi @patocarr appreciate the help
Get this error:
can't /build/tmp/work/plnx_zynqmp-xilinx-linux/base-files/3.0.14-r89/image/etc/udev/mount.blacklist: No such file or directory
Tried to find mount.blacklist didn't find it even after I build the project
Also Tried to create an app
petalinux-create -t apps -n mountblacklist --enable
mount.blacklist
/dev/loop
/dev/ram
/dev/mtdblock
/dev/md
/dev/dm-*
/dev/mmcblk0*
mountbalcklist.bb
# This file is the mountblacklist recipe.
SUMMARY = "Simple mountblacklist application"
SECTION = "PETALINUX/apps"
LICENSE = "MIT"
LIC_FILES_CHKSUM = "file://${COMMON_LICENSE_DIR}/MIT;md5=0835ade698e0bcf8506ecda2f7b4f302"
SRC_URI = "file://mount.blacklist \
S = "${WORKDIR}"
do_install() {
install -d ${D}${sysconfdir}/udev
install -m 0755 ${S}/mount.blacklist ${D}${sysconfdir}/udev/mount.blacklist
FILES_${PN} += "${sysconfdir}/*"
Didn't work
micki_b12
And then
And It work
