micki_b12
Petalinux 2018.2 update udev mount.blacklist file
I am using Peatlinux 2018.2 and I want to update mount.blacklist file located
root@wnc_16:/etc/udev# ls -l
total 7040
-r--r--r-- 1 root root 7198971 Oct 24 06:58 hwdb.bin
drwxr-xr-x 2 root root 360 Oct 24 06:58 hwdb.d
-rw-r--r-- 1 root root 51 Oct 24 06:50 mount.blacklist
drwxr-xr-x 2 root root 40 Oct 24 06:50 mount.blacklist.d
drwxr-xr-x 2 root root 140 Oct 24 06:58 rules.d
drwxr-xr-x 2 root root 80 Oct 24 06:58 scripts
-rw-r--r-- 1 root root 49 Jun 7 2018 udev.conf
Found this :
https://git.yoctoproject.org/cgit.cgi/poky/plain/meta/recipes-core/udev/eudev/
If I run grep in the project directory
build/tmp/pkgdata/plnx-zynqmp/runtime/udev-extraconf:17:CONFFILES_udev-extraconf: /etc/udev/mount.blacklist
build/tmp/pkgdata/plnx-zynqmp/runtime/udev-extraconf:18:FILES_INFO: {"/etc/udev/rules.d/localextra.rules": 843, "/etc/udev/scripts/mount.sh": 2469, "/etc/udev/mount.blacklist": 51, "/etc/udev/rules.d/automount.rules": 847, "/etc/udev/rules.d/autonet.rules": 757, "/etc/udev/scripts/network.sh": 1402}
I don't find mount.blacklist file in project directory
I understood it's PKG_udev-extraconf: udev-extraconf
I created a
project-spec/meta-user/recipes-core/udev/udev-extraconf
With file  udev-extraconf_%.bb and mount.black list
But it didn't work
Any Idea?
micki_b12
/project-spec/meta-user/recipes-core/udev$
drwxr-xr-x 2 mbalanga mbalanga 4096 Oct 25 11:01 udev-extraconf
-rw-r--r-- 1 mbalanga mbalanga 99 Oct 25 11:10 udev-extraconf_%.bbappenda
And then
do_install_append() {
sed -i '$s|$|\n/dev/mmcblk0*|' ${D}${sysconfdir}/udev/mount.blacklist
/project-spec/meta-user/recipes-core/udev/udev-extraconf$ ls -l
-rw-r--r-- 1 mbalanga mbalanga 66 Oct 25 09:21 mount.blacklist
And It work
micki_b12
And then
And It work
