Voyager
Voyager
Petalinux 2018.3 : [Hsi 55-1545] Problem running tcl command ::sw_axi_vcu::generate : param_value can only be empty if the param_type is boolean, value is must for other data types
Hello. Building petalinux with petalinux-tool 2018.3 using an hdf generated with Vivado 2018.3 I have this error executing petalinux-build:
ERROR: [Hsi 55-1545] Problem running tcl command ::sw_axi_vcu::generate : param_value can only be empty if the param_type is boolean, value is must for other data types
    while executing
"error "param_value can only be empty if the param_type is boolean, value is must for other data types""
    (procedure "hsi::utils::add_new_dts_param" line 3)
    invoked from within
"hsi::utils::add_new_dts_param "${encoder_node}" "interrupts" $intr_val int"
    (procedure "::sw_axi_vcu::generate" line 52)
    invoked from within
"::sw_axi_vcu::generate ZYNQ_VCU_vcu_0"
I rsad this https://forums.xilinx.com/t5/Embedded-Linux/How-to-patch-axi-vcu-tcl-in-Petalinux/td-p/943880 but it is about Vivado 2017.4 so it does not seem to relate to my problem.
Thank you very much.
Tags (3)
Voyager
Voyager
Re: Petalinux 2018.3 : [Hsi 55-1545] Problem running tcl command ::sw_axi_vcu::generate : param_value can only be empty if the param_type is boolean, value is must for other data types
Hi @stephenm,
In the messages I had a lot of warnigs about interrupts not conncted to an interupt controller. Connecting them all to an interrupt controller also this error disappeared. Thank you.
Voyager
Voyager
Anyone could help me?
A search about "param_value can only be empty if the param_type is boolean, value is must for other data types" error but I found nothing.
Can you share the HDF please and I will debug this for you?
Voyager
Voyager
Hi @stephenm,
Great
