Petalinux 2018.3 failed to build
When I try to build (petalinux-build) my petalinux project by Petalinux2018.3, I get device-tree build errors. I attached the log file.
stephenm
This is fixed in the latest DTG version. I have created a patch for 2018.3 that you can use. I tested this in 2018.3 and it works for me
For help using the patch, see the wiki here:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/136904764/Creating+Devicetree+from+Devicetree+Generator+for+Zynq+Ultrascale+and+Zynq+7000
jadhavs
Hi aysenurakinci805@gmail.com
Please have a look https://www.xilinx.com/support/answers/72007.html & https://www.xilinx.com/support/answers/72366.html
If this is not fixed then send me the HDF file to have a look.
Hi Jadhavs,
Thank you for interest. I tried but it doesn't work. My HDF file is attached.
Ayse Nur
stephenm
Thank you for helping Stephenm, it worked.
stephenm
Please mark this as solved please
