Petalinux 2018.3 failed to build
When I try to build (petalinux-build) my petalinux project by Petalinux2018.3, I get device-tree build errors. I attached the log file.
Best regards,
stephenm
This is fixed in the latest DTG version. I have created a patch for 2018.3 that you can use. I tested this in 2018.3 and it works for me
For help using the patch, see the wiki here:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/136904764/Creating+Devicetree+from+Devicetree+Generator+for+Zynq+Ultrascale+and+Zynq+7000
jadhavs
Hi aysenurakinci805@gmail.com
Please have a look https://www.xilinx.com/support/answers/72007.html & https://www.xilinx.com/support/answers/72366.html
If this is not fixed then send me the HDF file to have a look.
Hi Jadhavs,
Thank you for interest. I tried but it doesn't work. My HDF file is attached.
Best regards,
Ayse Nur
stephenm
Thank you for helping Stephenm, it worked.
Best regards,
stephenm
Please mark this as solved please
