02-07-2019 08:37 AM
I cannot use the PetaLinux rootfs because it is missing needed applications. An example of a needed missing item is tinydb Python module. The buildroot rootfs has the needed applications. But, in order to use the buildroot rootfs, I need the compiler executable.
When I run “petalinux-build --verbose”, and dig through the output, it looks like the name of the executable is “aarch64-xilinx-linux-gcc”. The following was found in the petalinux-build output.
make -f scripts/Makefile.build obj=libbb rm -f libbb/built-in.o; aarch64-xilinx-linux-ar rcs libbb/built-in.o aarch64-xilinx-linux-gcc --sysroot=/home/geoffrey/pzu19_udx_4k/build/tmp/work/aarch64-xilinx-linux/busybox/1.24.1-r0/recipe-sysroot -Wp,-MD,libbb/.appletlib.o.d -std=gnu99 -Iinclude -Ilibbb -include include/autoconf.h -D_GNU_SOURCE -DNDEBUG -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -D"BB_VER=KBUILD_STR(1.24.1)" -DBB_BT=AUTOCONF_TIMESTAMP -Wall -Wshadow -Wwrite-strings -Wundef -Wstrict-prototypes -Wunused -Wunused-parameter -Wunused-function -Wunused-value -Wmissing-prototypes -Wmissing-declarations -Wno-format-security -Wdeclaration-after-statement -Wold-style-definition -fno-builtin-strlen -finline-limit=0 -fomit-frame-pointer -ffunction-sections -fdata-sections -fno-guess-branch-probability -funsigned-char -static-libgcc -falign-functions=1 -falign-jumps=1 -falign-labels=1 -falign-loops=1 -fno-unwind-tables -fno-asynchronous-unwind-tables -fno-builtin-printf -Os -O2 -pipe -g -feliminate-unused-debug-types -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/geoffrey/pzu19_udx_4k/build/tmp/work/aarch64-xilinx-linux/busybox/1.24.1-r0=/usr/src/debug/busybox/1.24.1-r0 -fdebug-prefix-map=/home/geoffrey/pzu19_udx_4k/build/tmp/work/aarch64-xilinx-linux/busybox/1.24.1-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/geoffrey/pzu19_udx_4k/build/tmp/work/aarch64-xilinx-linux/busybox/1.24.1-r0/recipe-sysroot= -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(appletlib)" -D"KBUILD_MODNAME=KBUILD_STR(appletlib)" -c -o libbb/appletlib.o libbb/appletlib.c aarch64-xilinx-linux-gcc --sysroot=/home/geoffrey/pzu19_udx_4k/build/tmp/work/aarch64-xilinx-linux/busybox/1.24.1-r0/recipe-sysroot -Wp,-MD,libbb/.ask_confirmation.o.d -std=gnu99 -Iinclude -Ilibbb -include include/autoconf.h -D_GNU_SOURCE -DNDEBUG -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -D"BB_VER=KBUILD_STR(1.24.1)" -DBB_BT=AUTOCONF_TIMESTAMP -Wall -Wshadow -Wwrite-strings -Wundef -Wstrict-prototypes -Wunused -Wunused-parameter -Wunused-function -Wunused-value -Wmissing-prototypes -Wmissing-declarations -Wno-format-security -Wdeclaration-after-statement -Wold-style-definition -fno-builtin-strlen -finline-limit=0 -fomit-frame-pointer -ffunction-sections -fdata-sections -fno-guess-branch-probability -funsigned-char -static-libgcc -falign-functions=1 -falign-jumps=1 -falign-labels=1 -falign-loops=1 -fno-unwind-tables -fno-asynchronous-unwind-tables -fno-builtin-printf -Os -O2 -pipe -g -feliminate-unused-debug-types -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/geoffrey/pzu19_udx_4k/build/tmp/work/aarch64-xilinx-linux/busybox/1.24.1-r0=/usr/src/debug/busybox/1.24.1-r0 -fdebug-prefix-map=/home/geoffrey/pzu19_udx_4k/build/tmp/work/aarch64-xilinx-linux/busybox/1.24.1-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/geoffrey/pzu19_udx_4k/build/tmp/work/aarch64-xilinx-linux/busybox/1.24.1-r0/recipe-sysroot= -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(ask_confirmation)" -D"KBUILD_MODNAME=KBUILD_STR(ask_confirmation)" -c -o libbb/ask_confirmation.o libbb/ask_confirmation.c aarch64-xilinx-linux-gcc --sysroot=/home/geoffrey/pzu19_udx_4k/build/tmp/work/aarch64-xilinx-linux/busybox/1.24.1-r0/recipe-sysroot -Wp,-MD,libbb/.auto_string.o.d -std=gnu99 -Iinclude -Ilibbb -include include/autoconf.h -D_GNU_SOURCE -DNDEBUG -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -D"BB_VER=KBUILD_STR(1.24.1)" -DBB_BT=AUTOCONF_TIMESTAMP -Wall -Wshadow -Wwrite-strings -Wundef -Wstrict-prototypes -Wunused -Wunused-parameter -Wunused-function -Wunused-value -Wmissing-prototypes -Wmissing-declarations -Wno-format-security -Wdeclaration-after-statement -Wold-style-definition -fno-builtin-strlen -finline-limit=0 -fomit-frame-pointer -ffunction-sections -fdata-sections -fno-guess-branch-probability -funsigned-char -static-libgcc -falign-functions=1 -falign-jumps=1 -falign-labels=1 -falign-loops=1 -fno-unwind-tables -fno-asynchronous-unwind-tables -fno-builtin-printf -Os -O2 -pipe -g -feliminate-unused-debug-types -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/geoffrey/pzu19_udx_4k/build/tmp/work/aarch64-xilinx-linux/busybox/1.24.1-r0=/usr/src/debug/busybox/1.24.1-r0 -fdebug-prefix-map=/home/geoffrey/pzu19_udx_4k/build/tmp/work/aarch64-xilinx-linux/busybox/1.24.1-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/geoffrey/pzu19_udx_4k/build/tmp/work/aarch64-xilinx-linux/busybox/1.24.1-r0/recipe-sysroot= -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(auto_string)" -D"KBUILD_MODNAME=KBUILD_STR(auto_string)" -c -o libbb/auto_string.o libbb/auto_string.c BIN /home/geoffrey/pzu19_udx_4k/build/tmp/work/aarch64-xilinx-linux/arm-trusted-firmware/1.5-xilinx-v2018.3+gitAUTOINC+08560c36ea-r0/build/zynqmp/release/bl31.bin OD /home/geoffrey/pzu19_udx_4k/build/tmp/work/aarch64-xilinx-linux/arm-trusted-firmware/1.5-xilinx-v2018.3+gitAUTOINC+08560c36ea-r0/build/zynqmp/release/bl31/bl31.dump aarch64-xilinx-linux-gcc --sysroot=/home/geoffrey/pzu19_udx_4k/build/tmp/work/aarch64-xilinx-linux/busybox/1.24.1-r0/recipe-sysroot -Wp,-MD,libbb/.bb_askpass.o.d -std=gnu99 -Iinclude -Ilibbb -include include/autoconf.h -D_GNU_SOURCE -DNDEBUG -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -D"BB_VER=KBUILD_STR(1.24.1)" -DBB_BT=AUTOCONF_TIMESTAMP -Wall -Wshadow -Wwrite-strings -Wundef -Wstrict-prototypes -Wunused -Wunused-parameter -Wunused-function -Wunused-value -Wmissing-prototypes -Wmissing-declarations -Wno-format-security -Wdeclaration-after-statement -Wold-style-definition -fno-builtin-strlen -finline-limit=0 -fomit-frame-pointer -ffunction-sections -fdata-sections -fno-guess-branch-probability -funsigned-char -static-libgcc -falign-functions=1 -falign-jumps=1 -falign-labels=1 -falign-loops=1 -fno-unwind-tables -fno-asynchronous-unwind-tables -fno-builtin-printf -Os -O2 -pipe -g -feliminate-unused-debug-types -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/geoffrey/pzu19_udx_4k/build/tmp/work/aarch64-xilinx-linux/busybox/1.24.1-r0=/usr/src/debug/busybox/1.24.1-r0 -fdebug-prefix-map=/home/geoffrey/pzu19_udx_4k/build/tmp/work/aarch64-xilinx-linux/busybox/1.24.1-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/geoffrey/pzu19_udx_4k/build/tmp/work/aarch64-xilinx-linux/busybox/1.24.1-r0/recipe-sysroot= -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(bb_askpass)" -D"KBUILD_MODNAME=KBUILD_STR(bb_askpass)" -c -o libbb/bb_askpass.o libbb/bb_askpass.c Built /home/geoffrey/pzu19_udx_4k/build/tmp/work/aarch64-xilinx-linux/arm-trusted-firmware/1.5-xilinx-v2018.3+gitAUTOINC+08560c36ea-r0/build/zynqmp/release/bl31.bin successfully
But, when I try to run "aarch64-xilinx-linux-gcc --help", I end up with a "aarch64-xilinx-linux-gcc: command not found" error.
When I look at the directory tree structure generated by the PetaLinux 2018.3 tools install, I can find the following compilers.
./tools/linux-i386/microblazeel-xilinx-linux-gnu/bin/microblazeel-xilinx-linux-gnu-gcc ./tools/linux-i386/aarch64-none-elf/bin/aarch64-none-elf-gcc ./tools/linux-i386/gcc-arm-none-eabi/bin/arm-none-eabi-gcc ./tools/linux-i386/gcc-arm-linux-gnueabi/bin/arm-linux-gnueabihf-gcc ./tools/linux-i386/gcc-arm-none-eabi-r5/bin/armr5-none-eabi-gcc ./tools/linux-i386/aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc ./tools/linux-i386/microblaze-xilinx-elf/bin/microblaze-xilinx-elf-gcc ./tools/linux-i386/microblaze-xilinx-elf/bin/mb-gcc
Which compiler should be used? Where does aarch64-xilinx-linux-gcc come from?
The closest name in the list of available compilers above is aarch64-linux-gnu-gcc. Is this the one to use?
02-07-2019 07:47 PM
Use aarch64-linux-gnu-gcc
aarch64-xilinx-linux-gcc,which is located under build/tmp/work subdirectory, is built from scratch or copied from cache at the beginning of petalinux-build
When petalinux-build ends building process, it is removed
This is the reason you can't find aarch64-xilinx-linux-gcc
02-07-2019 07:47 PM
02-11-2019 07:39 AM - edited 02-11-2019 07:41 AM
I continued to dig after posting...
Reply from @hokim is consistent with https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841973/Build+U-Boot#Zynq
