nunu
Petalinux 2019.1 Interrupt Handling Zynq 7000
Hi at all,
this topic has been discussed from different perspectives.
Let me describe the basic infomation:
HostMachine: Ubuntu 18.04.3 LTS
Eval-Board: Myir Z-Turn Board 7020
Fpga-Design: is attached in a picture
A bare-metal version of the Interrupt-Handler is running.
The main task is to receive an input signal, which is detected by an IRQ and the Interrupt-Handler generates as a consequence a signal on a output pin.
Now I want to impliment a petalinux driver module with the same task.
During research I have found different methods to control the Interrupts.
The current state is that a petalinux image is running and skeleton of a driver module ist generate with:
  •   petalinux-create -t modules --name mymodule --enable
The first question is: How to connect the "Concate" IP-Block with the IRQ_F2P of the PS form a petalinux module? The input signal is a gpio without the AXI interface.
Some posts show the modification of device tree in this file:
  • project-spec/meta-user/recipes-bsp/device-tree/files/system-user.dtsi
I don't have fine a way to control the GIC like in the bare-metal version.
These entries should be a part of the system-user.dtsi file:
  • interrupt-parent = <&irq_cntlr>;
  • interrupts = <0 96 4>;
But which is the component that enclose them? intc?
I have seen that different Petalinux version has different approaches. How is the right way to handle Interrupts with the Petalinux ersion 2019.1?
Thx in advance.
thenumberdevil
I too have the same question.
  1. In Bare-metal application I could see interrupt handler registered at #define XPS_FPGA0_INT_ID 61U.
  2. What are the steps which we need to do to get the interrupt in the platform Linux driver module.
nunu
Hi have change the design on the input site and use now also AXI_GPIO:
After this the following device-tree part was created by the petalinux scripts:
folder: <proj>components/plnx_workspace/device-tree/device-tree/pl.dtsi
amba_pl: amba_pl {
#address-cells = <1>;
#size-cells = <1>;
compatible = "simple-bus";
ranges ;
Dip_Switches: gpio@41220000 {
#gpio-cells = <3>;
#interrupt-cells = <2>;
clock-names = "s_axi_aclk";
clocks = <&clkc 15>;
compatible = "xlnx,axi-gpio-2.0", "xlnx,xps-gpio-1.00.a";
gpio-controller ;
interrupt-controller ;
interrupt-names = "ip2intc_irpt";
interrupt-parent = <&intc>;
interrupts = <0 29 4>;
reg = <0x41220000 0x10000>;
xlnx,all-inputs = <0x1>;
xlnx,all-inputs-2 = <0x0>;
xlnx,all-outputs = <0x0>;
xlnx,all-outputs-2 = <0x0>;
xlnx,dout-default = <0x00000000>;
xlnx,dout-default-2 = <0x00000000>;
xlnx,gpio-width = <0x1>;
xlnx,gpio2-width = <0x20>;
xlnx,interrupt-present = <0x1>;
xlnx,is-dual = <0x0>;
xlnx,tri-default = <0xFFFFFFFF>;
xlnx,tri-default-2 = <0xFFFFFFFF>;
Input_Axi_Gpio: gpio@41230000 {
#gpio-cells = <3>;
gpio-controller ;
interrupts = <0 30 4>;
reg = <0x41230000 0x10000>;
axi_gpio_0: gpio@41200000 {
#gpio-cells = <3>;
gpio-controller ;
reg = <0x41200000 0x10000>;
xlnx,all-inputs = <0x0>;
xlnx,all-outputs = <0x1>;
xlnx,gpio-width = <0x3>;
xlnx,interrupt-present = <0x0>;
axi_gpio_1: gpio@41210000 {
#gpio-cells = <3>;
gpio-controller ;
reg = <0x41210000 0x10000>;
In the following user file, I have modified the single Gpio-nodes:
/project-spec/meta-user/recipes-bsp/device-tree/files/system-user.dtsi
/include/ "system-conf.dtsi"
amba_pl: amba_pl {
compatible = "dip_switches";interrupts = <0 29 1>;};
compatible = "input_axi_gpio";interrupts = <0 30 1>;};
compatible = "axi_gpio_0";};
compatible = "axi_gpio_1";};
The driver module is modified in the following section:
#ifdef CONFIG_OF
static struct of_device_id interruptdrv_of_match[] = {
{ .compatible = "dip_switches", },
{ .compatible = "input_axi_gpio", },
{ .compatible = "axi_gpio_0", },
{ .compatible = "axi_gpio_1", },
{ /* end of list */ },
MODULE_DEVICE_TABLE(of, interruptdrv_of_match);
#else
# define interruptdrv_of_match
#endif
With this configuration a boot up on the board is possible without errors of the driver (output dmesg).
From the output I see that the _probe function is called four time
like the amount of entries in the system-user.dtsi.
So the first question is:
  • How could be single gpio pins be manipulate through the driver?
The second questions is:
  • What are the advantages and
    disadvantage to this approach compared to the Sysfs approach?
*GPIO access
echo -n 906 > /sys/class/gpio/export
ls /sys/class/gpio
*chang to direction
cat /sys/class/gpio/gpio906/direction
->in
echo out > /sys/class/gpio/gpio906/direction
->out
*change value
echo 0 > /sys/class/gpio/gpio906/value
echo 1 > /sys/class/gpio/gpio906/value
A driver module Sysfs example could be found under this link:
https://gist.github.com/itrobotics/224a0c549ae073ce991c
Nunu
