Petalinux 2019.1 "Failed to open PetaLinux lib: librdi_commonxillic.so: cannot open shared object file" error!
I'm working with zcu106, petalinux 2019.1, vcu trd 2019.1 and Ubuntu 18.04.2
After command "petalinux-create -t project -s xilinx-vcu-trd-zcu106-v2019.1-final.bsp" I have the following error:
"Failed to open PetaLinux lib: librdi_commonxillic.so: cannot open shared object file".
I can't understand what's the problem. I installed all the libraries required in petalinux 2019.1 reference manual.
Thank you very much.
Edit:
This is the output of "strace petalinux-create"
execve("/home/administrator/opt/Xilinx/plinux/tools/common/petalinux/bin/petalinux-create", ["petalinux-create"], 0x7ffdb6600080 /* 56 vars */) = 0
brk(NULL)                               = 0x1315000
access("/etc/ld.so.nohwcap", F_OK)      = -1 ENOENT (No such file or directory)
access("/etc/ld.so.preload", R_OK)      = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=116214, ...}) = 0
mmap(NULL, 116214, PROT_READ, MAP_PRIVATE, 3, 0) = 0x7fa9e851f000
close(3)                                = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libdl.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0P\16\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=14560, ...}) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fa9e851d000
mmap(NULL, 2109712, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7fa9e8111000
mprotect(0x7fa9e8114000, 2093056, PROT_NONE) = 0
mmap(0x7fa9e8313000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7fa9e8313000
close(3)                                = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libc.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\260\34\2\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=2030544, ...}) = 0
mmap(NULL, 4131552, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7fa9e7d20000
mprotect(0x7fa9e7f07000, 2097152, PROT_NONE) = 0
mmap(0x7fa9e8107000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1e7000) = 0x7fa9e8107000
mmap(0x7fa9e810d000, 15072, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7fa9e810d000
close(3)                                = 0
mmap(NULL, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fa9e851a000
arch_prctl(ARCH_SET_FS, 0x7fa9e851a740) = 0
mprotect(0x7fa9e8107000, 16384, PROT_READ) = 0
mprotect(0x7fa9e8313000, 4096, PROT_READ) = 0
mprotect(0x609000, 4096, PROT_READ)     = 0
mprotect(0x7fa9e853c000, 4096, PROT_READ) = 0
munmap(0x7fa9e851f000, 116214)          = 0
getpid()                                = 3734
brk(0x1336000)                          = 0x1336000
execve("/bin/bash", ["petalinux-create", "-c", "exec 'petalinux-create' \"$@\"", "petalinux-create"], 0x1315a80 /* 59 vars */) = 0
brk(NULL)                               = 0x55c4fd618000
openat(AT_FDCWD, "/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/tls/haswell/x86_64/libtinfo.so.5", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/tls/haswell/x86_64", 0x7fff63bb52d0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/tls/haswell/libtinfo.so.5", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/tls/haswell", 0x7fff63bb52d0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/tls/x86_64/libtinfo.so.5", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/tls/x86_64", 0x7fff63bb52d0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/tls/libtinfo.so.5", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/tls", 0x7fff63bb52d0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/haswell/x86_64/libtinfo.so.5", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/haswell/x86_64", 0x7fff63bb52d0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/haswell/libtinfo.so.5", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/haswell", 0x7fff63bb52d0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/x86_64/libtinfo.so.5", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/x86_64", 0x7fff63bb52d0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/libtinfo.so.5", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o", 0x7fff63bb52d0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/Default/tls/haswell/x86_64/libtinfo.so.5", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/Default/tls/haswell/x86_64", 0x7fff63bb52d0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/Default/tls/haswell/libtinfo.so.5", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/Default/tls/haswell", 0x7fff63bb52d0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/Default/tls/x86_64/libtinfo.so.5", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/Default/tls/x86_64", 0x7fff63bb52d0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/Default/tls/libtinfo.so.5", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/Default/tls", 0x7fff63bb52d0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/Default/haswell/x86_64/libtinfo.so.5", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/Default/haswell/x86_64", 0x7fff63bb52d0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/Default/haswell/libtinfo.so.5", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/Default/haswell", 0x7fff63bb52d0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/Default/x86_64/libtinfo.so.5", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/Default/x86_64", 0x7fff63bb52d0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/Default/libtinfo.so.5", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/Default", 0x7fff63bb52d0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "tls/haswell/x86_64/libtinfo.so.5", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "tls/haswell/libtinfo.so.5", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "tls/x86_64/libtinfo.so.5", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "tls/libtinfo.so.5", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "haswell/x86_64/libtinfo.so.5", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "haswell/libtinfo.so.5", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "x86_64/libtinfo.so.5", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "libtinfo.so.5", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
mmap(NULL, 116214, PROT_READ, MAP_PRIVATE, 3, 0) = 0x7f6a2e055000
close(3)                                = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f6a2e053000
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libtinfo.so.5", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\220\311\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=170784, ...}) = 0
mmap(NULL, 2267936, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f6a2dc21000
mprotect(0x7f6a2dc46000, 2097152, PROT_NONE) = 0
mmap(0x7f6a2de46000, 20480, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x25000) = 0x7f6a2de46000
close(3)                                = 0
openat(AT_FDCWD, "tls/haswell/x86_64/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "tls/haswell/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "tls/x86_64/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "tls/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "haswell/x86_64/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "haswell/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "x86_64/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
mmap(NULL, 2109712, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f6a2da1d000
mprotect(0x7f6a2da20000, 2093056, PROT_NONE) = 0
mmap(0x7f6a2dc1f000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f6a2dc1f000
close(3)                                = 0
openat(AT_FDCWD, "tls/haswell/x86_64/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "tls/haswell/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "tls/x86_64/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "tls/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "haswell/x86_64/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "haswell/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "x86_64/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
mmap(NULL, 4131552, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f6a2d62c000
mprotect(0x7f6a2d813000, 2097152, PROT_NONE) = 0
mmap(0x7f6a2da13000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1e7000) = 0x7f6a2da13000
mmap(0x7f6a2da19000, 15072, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f6a2da19000
close(3)                                = 0
mmap(NULL, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f6a2e050000
arch_prctl(ARCH_SET_FS, 0x7f6a2e050740) = 0
mprotect(0x7f6a2da13000, 16384, PROT_READ) = 0
mprotect(0x7f6a2dc1f000, 4096, PROT_READ) = 0
mprotect(0x7f6a2de46000, 16384, PROT_READ) = 0
mprotect(0x55c4fc847000, 16384, PROT_READ) = 0
mprotect(0x7f6a2e072000, 4096, PROT_READ) = 0
munmap(0x7f6a2e055000, 116214)          = 0
openat(AT_FDCWD, "/dev/tty", O_RDWR|O_NONBLOCK) = 3
close(3)                                = 0
brk(0x55c4fd639000)                     = 0x55c4fd639000
openat(AT_FDCWD, "/usr/lib/locale/locale-archive", O_RDONLY|O_CLOEXEC) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=10281936, ...}) = 0
mmap(NULL, 10281936, PROT_READ, MAP_PRIVATE, 3, 0) = 0x7f6a2cc5d000
close(3)                                = 0
getuid()                                = 1000
getgid()                                = 1000
geteuid()                               = 1000
getegid()                               = 1000
rt_sigprocmask(SIG_BLOCK, NULL, [], 8)  = 0
ioctl(-1, TIOCGPGRP, 0x7fff63bb5ad4)    = -1 EBADF (Bad file descriptor)
sysinfo({uptime=2772, loads=[14784, 28320, 36192], totalram=8126181376, freeram=4072177664, sharedram=442109952, bufferram=129499136, totalswap=2147479552, freeswap=2147479552, procs=786, totalhigh=0, freehigh=0, mem_unit=1}) = 0
rt_sigaction(SIGCHLD, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f6a2d66af20}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, 8) = 0
rt_sigaction(SIGCHLD, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f6a2d66af20}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f6a2d66af20}, 8) = 0
rt_sigaction(SIGINT, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7f6a2d66af20}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, 8) = 0
rt_sigaction(SIGINT, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7f6a2d66af20}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7f6a2d66af20}, 8) = 0
rt_sigaction(SIGQUIT, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7f6a2d66af20}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, 8) = 0
rt_sigaction(SIGQUIT, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7f6a2d66af20}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7f6a2d66af20}, 8) = 0
rt_sigaction(SIGTSTP, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7f6a2d66af20}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, 8) = 0
rt_sigaction(SIGTSTP, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7f6a2d66af20}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7f6a2d66af20}, 8) = 0
rt_sigaction(SIGTTIN, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7f6a2d66af20}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, 8) = 0
rt_sigaction(SIGTTIN, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7f6a2d66af20}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7f6a2d66af20}, 8) = 0
rt_sigaction(SIGTTOU, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7f6a2d66af20}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, 8) = 0
rt_sigaction(SIGTTOU, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7f6a2d66af20}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7f6a2d66af20}, 8) = 0
rt_sigaction(SIGQUIT, {sa_handler=SIG_IGN, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7f6a2d66af20}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7f6a2d66af20}, 8) = 0
uname({sysname="Linux", nodename="pierluigi-ubuntu", ...}) = 0
stat("/home/administrator/BLT.Vivado/zcu106/progetti_plinux", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
stat(".", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
stat("/home", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
stat("/home/administrator", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
stat("/home/administrator/BLT.Vivado", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
stat("/home/administrator/BLT.Vivado/zcu106", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
getpid()                                = 3734
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/gconv/gconv-modules.cache", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=26376, ...}) = 0
mmap(NULL, 26376, PROT_READ, MAP_SHARED, 3, 0) = 0x7f6a2e06b000
close(3)                                = 0
getppid()                               = 3732
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/bin/petalinux-create", 0x7fff63bb5750) = -1 ENOENT (No such file or directory)
stat("/tools/Xilinx/SDK/2019.1/bin/petalinux-create", 0x7fff63bb5750) = -1 ENOENT (No such file or directory)
stat("/tools/Xilinx/SDK/2019.1/gnu/microblaze/lin/bin/petalinux-create", 0x7fff63bb5750) = -1 ENOENT (No such file or directory)
stat("/tools/Xilinx/SDK/2019.1/gnu/arm/lin/bin/petalinux-create", 0x7fff63bb5750) = -1 ENOENT (No such file or directory)
stat("/tools/Xilinx/SDK/2019.1/gnu/microblaze/linux_toolchain/lin64_le/bin/petalinux-create", 0x7fff63bb5750) = -1 ENOENT (No such file or directory)
stat("/tools/Xilinx/SDK/2019.1/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/petalinux-create", 0x7fff63bb5750) = -1 ENOENT (No such file or directory)
stat("/tools/Xilinx/SDK/2019.1/gnu/aarch32/lin/gcc-arm-none-eabi/bin/petalinux-create", 0x7fff63bb5750) = -1 ENOENT (No such file or directory)
stat("/tools/Xilinx/SDK/2019.1/gnu/aarch64/lin/aarch64-linux/bin/petalinux-create", 0x7fff63bb5750) = -1 ENOENT (No such file or directory)
stat("/tools/Xilinx/SDK/2019.1/gnu/aarch64/lin/aarch64-none/bin/petalinux-create", 0x7fff63bb5750) = -1 ENOENT (No such file or directory)
stat("/tools/Xilinx/SDK/2019.1/gnu/armr5/lin/gcc-arm-none-eabi/bin/petalinux-create", 0x7fff63bb5750) = -1 ENOENT (No such file or directory)
stat("/tools/Xilinx/SDK/2019.1/tps/lnx64/cmake-3.3.2/bin/petalinux-create", 0x7fff63bb5750) = -1 ENOENT (No such file or directory)
stat("/tools/Xilinx/DocNav/petalinux-create", 0x7fff63bb5750) = -1 ENOENT (No such file or directory)
stat("/tools/Xilinx/Vivado/2019.1/bin/petalinux-create", 0x7fff63bb5750) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/petalinux/bin/petalinux-create", 0x7fff63bb5750) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/common/petalinux/bin/petalinux-create", {st_mode=S_IFREG|0755, st_size=142176, ...}) = 0
geteuid()                               = 1000
getegid()                               = 1000
getuid()                                = 1000
getgid()                                = 1000
access("/home/administrator/opt/Xilinx/plinux/tools/common/petalinux/bin/petalinux-create", X_OK) = 0
geteuid()                               = 1000
getegid()                               = 1000
getuid()                                = 1000
getgid()                                = 1000
access("/home/administrator/opt/Xilinx/plinux/tools/common/petalinux/bin/petalinux-create", R_OK) = 0
geteuid()                               = 1000
getegid()                               = 1000
getuid()                                = 1000
getgid()                                = 1000
geteuid()                               = 1000
getegid()                               = 1000
getuid()                                = 1000
getgid()                                = 1000
getpid()                                = 3734
getpgrp()                               = 3732
ioctl(2, TIOCGPGRP, [3732])             = 0
rt_sigaction(SIGCHLD, {sa_handler=0x55c4fc59b720, sa_mask=[], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f6a2d66af20}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f6a2d66af20}, 8) = 0
prlimit64(0, RLIMIT_NPROC, NULL, {rlim_cur=30064, rlim_max=30064}) = 0
getpeername(0, 0x7fff63bb5ad0, [16])    = -1 ENOTSOCK (Socket operation on non-socket)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/bin/petalinux-create", 0x7fff63bb55a0) = -1 ENOENT (No such file or directory)
stat("/tools/Xilinx/SDK/2019.1/bin/petalinux-create", 0x7fff63bb55a0) = -1 ENOENT (No such file or directory)
stat("/tools/Xilinx/SDK/2019.1/gnu/microblaze/lin/bin/petalinux-create", 0x7fff63bb55a0) = -1 ENOENT (No such file or directory)
stat("/tools/Xilinx/SDK/2019.1/gnu/arm/lin/bin/petalinux-create", 0x7fff63bb55a0) = -1 ENOENT (No such file or directory)
stat("/tools/Xilinx/SDK/2019.1/gnu/microblaze/linux_toolchain/lin64_le/bin/petalinux-create", 0x7fff63bb55a0) = -1 ENOENT (No such file or directory)
stat("/tools/Xilinx/SDK/2019.1/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/petalinux-create", 0x7fff63bb55a0) = -1 ENOENT (No such file or directory)
stat("/tools/Xilinx/SDK/2019.1/gnu/aarch32/lin/gcc-arm-none-eabi/bin/petalinux-create", 0x7fff63bb55a0) = -1 ENOENT (No such file or directory)
stat("/tools/Xilinx/SDK/2019.1/gnu/aarch64/lin/aarch64-linux/bin/petalinux-create", 0x7fff63bb55a0) = -1 ENOENT (No such file or directory)
stat("/tools/Xilinx/SDK/2019.1/gnu/aarch64/lin/aarch64-none/bin/petalinux-create", 0x7fff63bb55a0) = -1 ENOENT (No such file or directory)
stat("/tools/Xilinx/SDK/2019.1/gnu/armr5/lin/gcc-arm-none-eabi/bin/petalinux-create", 0x7fff63bb55a0) = -1 ENOENT (No such file or directory)
stat("/tools/Xilinx/SDK/2019.1/tps/lnx64/cmake-3.3.2/bin/petalinux-create", 0x7fff63bb55a0) = -1 ENOENT (No such file or directory)
stat("/tools/Xilinx/DocNav/petalinux-create", 0x7fff63bb55a0) = -1 ENOENT (No such file or directory)
stat("/tools/Xilinx/Vivado/2019.1/bin/petalinux-create", 0x7fff63bb55a0) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/petalinux/bin/petalinux-create", 0x7fff63bb55a0) = -1 ENOENT (No such file or directory)
geteuid()                               = 1000
getegid()                               = 1000
getuid()                                = 1000
getgid()                                = 1000
geteuid()                               = 1000
getegid()                               = 1000
getuid()                                = 1000
getgid()                                = 1000
geteuid()                               = 1000
getegid()                               = 1000
getuid()                                = 1000
getgid()                                = 1000
geteuid()                               = 1000
getegid()                               = 1000
getuid()                                = 1000
getgid()                                = 1000
rt_sigaction(SIGQUIT, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7f6a2d66af20}, {sa_handler=SIG_IGN, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7f6a2d66af20}, 8) = 0
rt_sigaction(SIGCHLD, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f6a2d66af20}, {sa_handler=0x55c4fc59b720, sa_mask=[], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f6a2d66af20}, 8) = 0
execve("/home/administrator/opt/Xilinx/plinux/tools/common/petalinux/bin/petalinux-create", ["petalinux-create"], 0x55c4fd625300 /* 59 vars */) = 0
brk(NULL)                               = 0x25a0000
openat(AT_FDCWD, "/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/tls/haswell/x86_64/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/tls/haswell/x86_64", 0x7ffcf522fe20) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/tls/haswell/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/tls/haswell", 0x7ffcf522fe20) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/tls/x86_64/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/tls/x86_64", 0x7ffcf522fe20) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/tls/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/tls", 0x7ffcf522fe20) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/haswell/x86_64/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/haswell/x86_64", 0x7ffcf522fe20) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/haswell/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/haswell", 0x7ffcf522fe20) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/x86_64/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/x86_64", 0x7ffcf522fe20) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o", 0x7ffcf522fe20) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/Default/tls/haswell/x86_64/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/Default/tls/haswell/x86_64", 0x7ffcf522fe20) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/Default/tls/haswell/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/Default/tls/haswell", 0x7ffcf522fe20) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/Default/tls/x86_64/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/Default/tls/x86_64", 0x7ffcf522fe20) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/Default/tls/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/Default/tls", 0x7ffcf522fe20) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/Default/haswell/x86_64/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/Default/haswell/x86_64", 0x7ffcf522fe20) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/Default/haswell/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/Default/haswell", 0x7ffcf522fe20) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/Default/x86_64/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/Default/x86_64", 0x7ffcf522fe20) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/Default/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/administrator/opt/Xilinx/plinux/tools/xsct/lib/lnx64.o/Default", 0x7ffcf522fe20) = -1 ENOENT (No such file or directory)
mmap(NULL, 116214, PROT_READ, MAP_PRIVATE, 3, 0) = 0x7f4fe62e7000
close(3)                                = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f4fe62e5000
mmap(NULL, 2109712, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f4fe5ed9000
mprotect(0x7f4fe5edc000, 2093056, PROT_NONE) = 0
mmap(0x7f4fe60db000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f4fe60db000
close(3)                                = 0
mmap(NULL, 4131552, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f4fe5ae8000
mprotect(0x7f4fe5ccf000, 2097152, PROT_NONE) = 0
mmap(0x7f4fe5ecf000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1e7000) = 0x7f4fe5ecf000
mmap(0x7f4fe5ed5000, 15072, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f4fe5ed5000
close(3)                                = 0
mmap(NULL, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f4fe62e2000
arch_prctl(ARCH_SET_FS, 0x7f4fe62e2740) = 0
mprotect(0x7f4fe5ecf000, 16384, PROT_READ) = 0
mprotect(0x7f4fe60db000, 4096, PROT_READ) = 0
mprotect(0x7f4fe6304000, 4096, PROT_READ) = 0
munmap(0x7f4fe62e7000, 116214)          = 0
getpid()                                = 3734
brk(0x25c1000)                          = 0x25c1000
getuid()                                = 1000
openat(AT_FDCWD, "tls/haswell/x86_64/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "tls/haswell/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "tls/x86_64/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "tls/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "haswell/x86_64/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "haswell/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "x86_64/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
close(3)                                = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/tls/haswell/x86_64/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/lib/x86_64-linux-gnu/tls/haswell/x86_64", 0x7ffcf522fbf0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/tls/haswell/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/lib/x86_64-linux-gnu/tls/haswell", 0x7ffcf522fbf0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/tls/x86_64/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/lib/x86_64-linux-gnu/tls/x86_64", 0x7ffcf522fbf0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/tls/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/lib/x86_64-linux-gnu/tls", 0x7ffcf522fbf0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/haswell/x86_64/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/lib/x86_64-linux-gnu/haswell/x86_64", 0x7ffcf522fbf0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/haswell/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/lib/x86_64-linux-gnu/haswell", 0x7ffcf522fbf0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/x86_64/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/lib/x86_64-linux-gnu/x86_64", 0x7ffcf522fbf0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/lib/x86_64-linux-gnu", {st_mode=S_IFDIR|0755, st_size=12288, ...}) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/tls/haswell/x86_64/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib/x86_64-linux-gnu/tls/haswell/x86_64", 0x7ffcf522fbf0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/tls/haswell/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib/x86_64-linux-gnu/tls/haswell", 0x7ffcf522fbf0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/tls/x86_64/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib/x86_64-linux-gnu/tls/x86_64", 0x7ffcf522fbf0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/tls/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib/x86_64-linux-gnu/tls", 0x7ffcf522fbf0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/haswell/x86_64/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib/x86_64-linux-gnu/haswell/x86_64", 0x7ffcf522fbf0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/haswell/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib/x86_64-linux-gnu/haswell", 0x7ffcf522fbf0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/x86_64/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib/x86_64-linux-gnu/x86_64", 0x7ffcf522fbf0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib/x86_64-linux-gnu", {st_mode=S_IFDIR|0755, st_size=69632, ...}) = 0
openat(AT_FDCWD, "/lib/tls/haswell/x86_64/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/lib/tls/haswell/x86_64", 0x7ffcf522fbf0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/lib/tls/haswell/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/lib/tls/haswell", 0x7ffcf522fbf0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/lib/tls/x86_64/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/lib/tls/x86_64", 0x7ffcf522fbf0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/lib/tls/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/lib/tls", 0x7ffcf522fbf0)        = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/lib/haswell/x86_64/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/lib/haswell/x86_64", 0x7ffcf522fbf0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/lib/haswell/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/lib/haswell", 0x7ffcf522fbf0)    = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/lib/x86_64/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/lib/x86_64", 0x7ffcf522fbf0)     = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/lib/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/lib", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
openat(AT_FDCWD, "/usr/lib/tls/haswell/x86_64/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib/tls/haswell/x86_64", 0x7ffcf522fbf0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/tls/haswell/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib/tls/haswell", 0x7ffcf522fbf0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/tls/x86_64/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib/tls/x86_64", 0x7ffcf522fbf0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/tls/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib/tls", 0x7ffcf522fbf0)    = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/haswell/x86_64/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib/haswell/x86_64", 0x7ffcf522fbf0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/haswell/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib/haswell", 0x7ffcf522fbf0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/x86_64/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib/x86_64", 0x7ffcf522fbf0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/librdi_commonxillic.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
write(2, "Failed to open PetaLinux lib: li"..., 113Failed to open PetaLinux lib: librdi_commonxillic.so: cannot open shared object file: No such file or directory.
) = 113
exit_group(-1)                          = ?
+++ exited with 255 +++
Re: Petalinux 2019.1 "Failed to open PetaLinux lib: librdi_commonxillic.so: cannot open shared object file" error!
I found a workaround for this error. Installing petalinux in "/home/administrator/opt/Xilinx/plinux" generate installation errors. So I installed petalinux in /home/administrator/plinux and now it works.
rather than move your project, you can include the xilinx shared libraries using ldconfig
sudo echo "/opt/Xilinx/petalinux/tools/lib" > /etc/ld.so.conf.d/petalinux.so.conf
sudo ldconfig
I am getting this error when i try and create a module within a petalinux project;
PetaLinux environment set to '/home/user/petalinux'
INFO: Checking free disk space
INFO: Checking installed tools
INFO: Checking installed development libraries
INFO: Checking network and other services
WARNING: No tftp server found - please refer to "PetaLinux SDK Installation Guide" for its impact and solution
user@VM-VirtualBox:~$ cd rfSoC/rfSoC/
user@VM-VirtualBox:~/rfSoC/rfSoC$ petalinux-create -t modules --name testmodule --enable
INFO: Create modules: testmodule
INFO: New modules successfully created in /home/user/rfSoC/rfSoC/project-spec/meta-user/recipes-modules/testmodule
INFO: Enabling created component...
INFO: sourcing bitbake
INFO: oldconfig rootfs
INFO: testmodule has been enabled
However the file exists;
user@VM-VirtualBox:~/rfSoC$ ls -la ~/petalinux/tools/xsct/lib/lnx64.o/librdi_commonxillic.so
-rwxr-xr-x 1 user user 3118192 May 11 21:09 /home/user/petalinux/tools/xsct/lib/lnx64.o/librdi_commonxillic.so
This error is the same if i create a new project or add a module to an existing project that had previously had modules successfully created (from the same installation)
Thanks for the suggestion! I was having a similar problem where it seemed to find the file but then failed. Running strace caused an eventual crash, and ltrace produced this final line before exiting:
dlopen("librdi_commonxillic.so", 10Couldn't find .rel*.plt section in "/opt/pkg/petalinux/2019.1/tools/xsct/lib/lnx64.o/libisl_iostreams.so"
I did the ldconf and the problem is gone.
Cheers, Tom
@tgschneider I assume you pointed ldconfig t your location, 2019.1 seems to be different..
So;
sudo echo "/opt/pkg/petalinux/2019.1/tools/xsct/lib/lnx64.o" > /etc/ld.so.conf.d/petalinux.so.conf
sudo ldconfig
I did the ldconfig settings for my configuration;
      sudo echo“/var/data/petalinux_2019_1/tools/xsct/lib/lnx64.o" > /etc/ld.so.conf.d/petalinux.so.conf
      sudo ldconfig
Now i get the error;
Failed to open PetaLinux lib: /lib64/libstdc++.so.6: version `GLIBCXX_3.4.20' not found (required by /var/data/petalinux_2019_1/tools/xsct/lib/lnx64.o/librdi_commonxillic.so).
libstdc++.so.6 is located on my installation (RedHat Enterprice 7) at:
/var/data/petalinux_2019_1/tools/xsct/lib/lnx64.o/Default
/var/data/petalinux_2019_1/tools/xsct/lib/lnx64.o/SuSE
/var/data/petalinux_2019_1/tools/xsct/lib/lnx64.o/Ubuntu
I have tried exporitng the default path but have the same error;
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/var/data/petalinux_2019_1/tools/xsct/lib/lnx64.o/Default/
