vvanbeveren
Petalinux 2019.1 u-boot crash when using gpio_led driver
I am in the process of upgrading a project from petalinux 2018.2 to 2019.1. Everything in 2019.1 builds fine, but when booting u-boot crashes with the following remark:
U-Boot 2019.01 (Oct 08 2019 - 09:44:32 +0000) Xilinx Zynq ZC702
CPU:   Zynq 7z030
Silicon: v3.1
DRAM:  ECC disabled 1 GiB
Error binding driver 'gpio_led': -22
Some drivers failed to bind
initcall sequence 3ffbb34c failed at call 00412dd4 (err=-22)
### ERROR ### Please RESET the board ###
I think this may be releated to the usage of the gpio-leds driver, because I have extended by device-tree with the following (which worked fine in 2018.2):
    /* Configure blinky LEDs! */
    leds {
            compatible = "gpio-leds";
            heartbeat {
                    gpios = <&gpio0 0 0>;
                    default-state = "off";
                    linux,default-trigger = "heartbeat";
So, what could cause this to fail in 2019.1? Any help is welcome!
Kind regards,
Vincent
gudishak
Hi @vvanbeveren
I see below device tree node in final device tree in zynqMP zcu102 board.
Could you please take below device tree as reference?
leds {
heartbeat_led {
label = "heartbeat";
gpios = <0x14 0x17 0x0>;
Best Regards
Kranthi
gudishak
Hi @vvanbeveren
leds {
heartbeat_led {
Best Regards
Kranthi
stephenm
Is the PL configured too:
petalinux-package --boot --fpga system.bit --u-boot
vvanbeveren
Hi Kranthi,
I modified my device tree entry similar to yours (renamed heartbeat to heartbeat_led and added the label statement) and it works! I don't know exactly what did it , but thanks!
Kind regards,
Vincent
vvanbeveren
Hi Stephen,
Yes, the pl was loaded.
Vincent
