radFITimage
Petalinux 2019.2 Applying Kernel Config
I am looking to understand how a kernel patch should be applied using petalinux-config -c kernel for 2019.2. I have extracted a bsp.cf file and have added a linux-xlx_%%.bbappend. This does not appear to be picked up and when I distclean or clean it fails to get applied properly.
I tried the petalinux-build -c kernel -x finish but this also fails but this is a different issue.
Can the .bbappend for 2019.2 be supplied it appears to have changed with 2018.3 and 2020.1 based on my research so it is hard to determine what works in 2019.2
aravindb
HI @radFITimage
Can you please follow steps mentioned in this link forum post:https://forums.xilinx.com/t5/Embedded-Linux/petalinux-2020-1-kernel-config-file/td-p/1147298
That should help, incase if you still see the issues let me know.
Thanks & regards
Aravind
aravindb
HI @radFITimage
Thanks & regards
Aravind
radFITimage
Thanks for clarifying. I am currently having issues with -x finish working. It errors out. I attempted the fix to this by changing the URI but this did not work.It appears to  be linked in linix-xlnx repo mirror UI in the petalinux config in 2019.2.
I was able to manually execute the patch and have made user.cfg trying both devtool-fragment.cfg and can see this added into the work/plnx_zynqpm-xilinx-linux/4.19-xilinx-v2019.2+git999 but it does not appear in the image. I am going to do a distclean and try again.
radFITimage
I missed the critical step of:
SRCTREECOVEREDTASKS_remove_pn-linux-xlnx = "do_kernel_configme"
