Petalinux 2019.2 - howto place kernel config under version control
Greetings!
We have a number of developers and I need everyone to be using the same kernel config, so I need it placed under version control.
After blowing away the "build" and "components" directories, then executing "petalinux-config -c kernel" and making my changes, I find the following two files have appeared (in addition to many others):
<plnx-project>/components/plnx_workspace/sources/linux-xlnx/.config.baseline
<plnx-projext>/components/plnx_workspace/sources/linux-xlnx/.config.new
I also see that .config.new is actually a symlink to :
<plnx-project>/build/tmp/work/plnx_zynqmp-xilinx-linux/linux-xlnx/4.19-xilinx-v2019.2+git999-r0/linux-xlnx-4.19-xilinx-v2019.2+git999//.config
A diff between the two files shows that .config.new is based on .config.baseline, and indeed has all my kernel config updates in it.
Here's the rub: according to UG1144 (page 22), the build and components/plnx_workspace directories can be ignored from a version control perspective - but it seems that .config.baseline and .config.new are essential.  I'm not keen on placing build and components/plnx_workspace directories under version control.  How do I proceed?
- Is there a Yocto mechanism I can use to place .config.baseline and .config.new somewhere in the project-spec directory, plug them into BitBake, and have them included as part of the build?
- Where is the source of the .config.baseline file?  It is possible to modify it with my kernel config changes?
- Is there a minimum/essential set of files/directories I can place under version control?
- Is there something I'm missing or a better way to do this?
Thanks in advance for any suggestions!
-Dave
Re: Petalinux 2019.2 - howto place kernel config under version control
Same issue. PetaLinux 2018.3 automatically creates kernels fragmets at the
<root>/project-spec/meta-user/recipes-kernel/linux/linux-xlnx/user_<DATE_TIME>.cfg
and adds this fragments into
project-spec/meta-user/recipes-kernel/linux/linux-xlnx_%%.bbappend
PetaLinux 2019.2 does not.
Related post with possible WA: https://forums.xilinx.com/t5/Embedded-Linux/Petalinux-2019-2-kernel-configuration-issues/td-p/1050292
Solution:
For those of you who may find their way to this issue, I'll describe my method to putting the Linux kernel and u-boot configurations safely under version control.  Special thanks to adrozdov for providing a link that eventually revealed a slick solution!
===== kernel configuration =====
1- Execute "petalinux-config -c kernel", and make any changes (either adding or subtracting functionality)
2- "cd" to the top of your project.  Unlike other petalinux-xxx commands, this one MUST be run from the top level.
3- Execute "petalinux-build -c kernel -x finish".  When this command is complete, you'll find the following have been added:
    <plnx-project>/project-spec/meta-user/recipes-kernel/linux/linux-xlnx_%.bbappend
    <plnx-project>/project-spec/meta-user/recipes-kernel/linux/linux-xlnx/devtool-fragment.cfg
An examination of the devtool-fragment.cfg file will show the change deltas from the kernel baseline to your config.
The next time you run a kernel configuration, this file will be included so the kernel configuration you'll be presented already has your changes applied.  If you'd like to start over from scratch with a kernel config baseline, you can delete the above files. Be cautious that you don't remove other files placed in the dir tree; but in my case, I was able to delete the recipes-kernel folder (and everything below) from meta-user.
Once completed, you can place the following directories and files under version control:
A fresh version control checkout followed by a build had all my kernel configs properly applied!
===== u-boot configuration =====
1- Execute "petalinux-config -c u-boot", and make any changes (either adding or subtracting functionality)
3- Execute "petalinux-build -c u-boot -x finish".  If errors are shown, append the command with " -f" to force the operation.
    When this command is complete, you'll find the following:
    <plnx-project>/project-spec/meta-user/recipes-bsp/u-boot/u-boot-xlnx_%.bbappend  (modified)
    <plnx-project>/project-spec/meta-user/recipes-bsp/u-boot/files/devtool-fragment.cfg  (added)
    <plnx-project>/project-spec/meta-user/recipes-bsp/u-boot/files/microblaze-kc705-Convert-microblaze-generic-to-k.patch  (added)
An examination of the devtool-fragment.cfg file will show the change deltas from the u-boot baseline to your config.
The next time you run a u-boot configuration, this file will be included so the u-boot configuration you'll be presented already has your changes applied.
Once completed, you can add the following directories and files under version control:
A fresh version control checkout followed by a build had all my u-boot configs properly applied!
Scholar vanmierlo
I assume that when you want to make further changes to the configuration, you have to rerun "petalinux-build -c kernel -x finish" to get the files updated for a commit.
It is not an option. After that procedure, sources at the "components/plnx_workspace/sources/linux-xlnx" will be deletect and another kernel build process will start from scratch. I prefer fast & light git commits and kernel finishing affect work process heavily.
