vishu26
Petalinux 2020.2: interrupts information not getting generated in pl.dtsi
I am using Petalinux Version 2020.2. Using Vivado 2020.2, an IP in PL is created. The IP has four PL-PS interrupts an are configured as shown.
The interrupts in the PS are also enabled as shown.
Using the above design, I generate .xsa file which I use in the petalinux project.
In the petalinux project, I call
petaliunx-config --get-hw-description
Following this device tree files are generated in <plnx-project> > components > plnx_workspace > device-tree > device-tree
My pl.dtsi file looks like as follows:
The problem is that no interrupt information for PL part is produced by petalinux. So I assume it can be one of the following problems
  1. Etither I need to enable something in Vivado design to activate interrupts in PL.
  2. Or the petalinux is failing to generate interrupt information for the PL part.
I would be glad if someone can help.
Thanks and Regards
Vishav
stephenm
The DTG looks for all pins of type interrupt when generating the interrupt node properties. You can go through a concat IP, or a vector logic. The DTG will do a few hops to try find the interrupt source pin.
In your custom IP, this is not the case.
So, you have two solutions:
  1. Fix it in HW and regenerate the HW (as discussed above)
  2. Manually add the DT node in your petalinux project (discussed below)
Assuming this is the interrupt here:
This is connected to IRQ_F2P 88
So, you can update the system-user.dtsi with this info (88 - 32 (SPI) = 56)
https://github.com/Xilinx/device-tree-xlnx/blob/master/device_tree/data/common_proc.tcl#L258
& rt_axi_if_dsbl_netlist_0 {
   interrupt-parent = <&gic>;
   interrupts = <0 56 4>;
maps-mpls
Mentor
Mentor
Your pop up windows are highlighting basic interrupt connectivity.  But they mask what is driving those interrupts.
Is it standard IP from the IP catalog, or custom IP done by you or a hardware designer?
*** Destination: Rapid design and development cycles *** Unappreciated answers get deleted, unappreciative OPs get put on ignored list ***
hokim
Probably the interrupt line of your custom ip is not interrupt type
Did you do step 4 at https://www.xilinx.com/support/documentation/sw_manuals/xilinx2020_2/ug1118-vivado-creating-packaging-custom-ip.pdf#page=42 ?
vishu26
Hi @maps-mpls
It is a custom IP done by a hardware designer. Can I enable the interrupts on my own or do I need to ask hardware designer?
Thanks & Regards
Vishav
vishu26
Hi @hokim
Unfortunately I did not design the custom IP. Is there a way that I can proof if interrupt support is missing in IP block?
Thanks and Regards
Vishav
hokim
Only interrupt type pin should be connected to IRQF2P
You can check it in vivado pin properties
The interrupt pin should be like this
You have to ask hardware designer to set the pin to interrupt type
vishu26
Hi @hokim
Thanks for the answer. I am a newbie to Vivado tools. How do I access block pin properties? All I see is block properties.
Thanks and Regards
Vishav
hokim
You have to click not ip but pin of ip
vishu26
Thanks for help. I found out the pin properties. There is no CONFIG tab in the pin properties and hence no senstivity settings. Can I add them on my own?
maps-mpls
Mentor
Mentor
If this is a real project, your company is losing money relearning over the course of weeks what could have been taught in training over a few days.
The best way for the hardware guy to solve this quickly is for him to create and package some new IP in a throwaway project, check the interrupt support box, and then look at the generated HDL, and apply the generics and signal names found on that throw away project to his.  Also pay attention to the contents of components.xml.  This is a quick and dirty hackish answer, but it should get you going.  There are better and more elegant ways of doing things, and a lot of unclean hackish ways.  I just highlighted one way.
stephenm
vishu26
Hi @stephenm
Thanks for answer. I already tried this. But unfortunately I did not get the expected results. Here is how my sytem-user.dtsi file now looks like
/* default */
chosen {
    bootargs = "console=ttyPS0,115200 earlyprintk uio_pdrv_genirq.of_id=generic-uio";
amba_pl: amba_pl {
                rt_axi_if_dsbl_netlist_0: rt_axi_if_dsbl_netlist@7aa00000 {
                            interrupt-parent = <0x3>;
                            interrupts = <0 29 4>;
                            compatible = "generic-uio";
I successfully compiled the kernel, flashed and booted it on my board. But when I run
cat /proc/interrupts
The result is:
As you can see, there is no interrupt listed for my added custom interrupt. It would be great to know what am I doing wrong here.
Thanks and Regards,
Vishav
stephenm
Can you try my DT node that I posted in the previous thread?
vishu26
I get a build error. It does not recognize the label gic. What does it corresponds to? Could that be a problem ? Attached is the build log.
Thanks and Regards
Vishav
stephenm
This is the name of the ps interrupt controller. Can you send the XSA?
maps-mpls
Mentor
Mentor
I'd ask the hardware designer to do what I suggested above, or what @hokim suggested, if it is really custom IP.  (There is more than one way to do it right, and many many ways to do it wrong).
Also, I'd be careful about uploading XSAs to a public forum.  It helps us, as you will see, but you're also sharing more of the design than you might have realized.
Your xlconcat_0 has 8 interrupts in the xsa you posted, not the 4 shown in your first screen capture of xlconcat_0.
And all of them are standard Xilinx IP from the IP catalog, not custom IP.
xilinx.com:ip:axi_quad_spi:3.2
xilinx.com:ip:axi_gpio:2.0
xilinx.com:ip:axi_uart16550:2.0 ; # UART_A
xilinx.com:ip:axi_uart16550:2.0 ; # UART 3
xilinx.com:ip:axi_uart16550:2.0 ; # UART 4
xilinx.com:ip:axi_uart16550:2.0 ; # UART 5
xilinx.com:ip:axi_uart16550:2.0 ; # UART 6
Consequently, the XSA does not seem to match the screen capture you posted, and the fact that these are all commonly used Xilinx IPs means it is not likely the interrupt pins were specified incorrectly.  Did you post the wrong XSA?  Take a screen shot of the wrong .bd?   Misunderstand what your audience would understand by the term "custom IP"?  The only custom IP I see in the block diagram is a module for LEDs, and it doesn't seem to have anything to do with interrupts.
Anyway, good luck, too much chaos from what I am seeing for me to be of help.
vishu26
@maps-mpls @stephenm
I am really sorry for the mistake. I posted the wrong xsa file. Here is the correct one.
Again, please accept my apologies.
Vishav
stephenm
So, just to clarify. They better fix is to fix this in HW. However, you can compensate for missing info by manually doing this in the DT.
Can you try update your system-user.dtsi as shown below:
/include/ "system-conf.dtsi"
&rt_axi_if_dsbl_netlist_0 {
interrupt-parent = <&intc>;
vishu26
Hi @stephenm
Thanks for the information. This thing worked. However, I have one more question. How do I configure multiple interrupts in the same device? Or do I need to configure a new device for each interrupt?
Vishav
stephenm
Ok, great
You would do this in your driver. Then you handler would determine the source of the interrupt within your IP.
