berk_era
Petalinux: AXI_STREAM_FIFO cannot be seen as a device in petalinux (/dev/axis_fifo)
We are trying to implement AXI STREAM FIFO (v4.2) to our petalinux 2019.2 driven design with Vivado 2019.2 on Ultrascale+ device. Even though, we can see the device in device tree and observe the axi address on vivado project, we cannot see the device on linux as /dev/axis_fifo. We found a linux driver on Xilinx forum, applied that to our desgin but it seems like it didnt have any effect on our problem. In petalinux 2019.2, we followed the following set:
*petalinux-config -c kernel
and found and added the axis fifo driver in "menuconfig". Also, we tried this "https://github.com/jacobfeder/axisfifo" driver and added as a module in our petalinux project. Yet, we couldnt see the axis_fifo device as "/dev/axis_fifo" on both trials. We tired these methods independently.
So, what might be the  root cause of our problem and how can we solve it.
Sincerely,
ps: The same desing worked as intended on vivado 2018.2  and  petalinux 2018 .2 (on Zynq and ip version 4.1.). But, our design runs on ultrascale+, Vivado 2019.2 and petalinux 2019.2 with "AXI STREAM FIFO v4.2".
-Coşkun Berk
cyt_era
Is there anyone here to say how to resolve this issue?
crepe
Same issue in 2018.3... Any update?
dyessgg
I realize this topic is a few months old by now.  Did you try adding 'status = "okay";' to your device tree file?
jcrash29
This is how I managed to fix this issue.
It appears that althought 2019.2+ use AXI Stream FIFO 4.2. The petalinux kernel still includes only version 4.1
This means that the PL.dtsi file generated by petalinux has a compatability mode as the following
axi_fifo_mm_s_0: axi_fifo_mm_s@420000000 {
			clock-names = "s_axi_aclk";
			clocks = <&misc_clk_0>;
			compatible = "xlnx,axi-fifo-mm-s-4.2";
Notice the 4.2
The petalinux driver however is still using compatibility 4.1 HERE
static const struct of_device_id axis_fifo_of_match[] = {
	{ .compatible = "xlnx,axi-fifo-mm-s-4.1", },
The fix:
Add the following to system-user.dtsi
&axi_fifo_mm_s_0{
	compatible = "xlnx,axi-fifo-mm-s-4.1";
I have not yet seen any compatibility issues with the driver.
