dikon
Petalinux: Bug in targetroot-inst.sh?
I may have discovered a bug in the targetroot-inst.sh shell script in the components/rootfs subdirectory of the Petalinux 2014.4 installation directory:
In the sub function file_copy(), in the line
find . -print | grep -E -v '/CVS|/\.svn' | cpio -p${V}dumL ${TARGETDIR}${dst}
the "L" option to cpio leads to a dereferencing of all symbolic links in the custom apps that I've included in my Petalinux project. I.e. suppose if I have a binary myapp and a symbolic link myapp2 which points to myapp and a Makefile-entry
install:
  $(TARGETINST) -v -d data /usr/bin
that copies data/myapp and data/myapp2 to /usr/bin. Now, when I'm booting the linux image, myapp and myapp2 in /usr/bin are two identical files instead of myapp2 being a symbolic link to myapp. That unnecessarily blows up the linux image and leads to image size problems.
Removing the "L" option, i.e. replacing above line with
find . -print | grep -E -v '/CVS|/\.svn' | cpio -p${V}dum ${TARGETDIR}${dst}
seems to be the solution to this problem. So what is the intention for the L option or is it simply a bug?
sylvain.ellisys
Same question here. The L option to cpio is quite annoying, and it's still present in 2015.2.
While I am very tempted to remove it, I would like to make sure I don't miss a critical reason for this option to have been introduced...
Thanks in advance.
