Petalinux Build Error 2018.1
Hi everybody!
I am stuck at one error, I followed the README instruction which comes with BSP package.
I have selected following:
openamp-fw-echo-testd
openamp-fw-mat-muld
openamp-fw-rpc-demo
After doing the changes as per the README, I exectured "petalinux-build' command. After this, build error, thus unsuccessful building. Error is captured in the attached files, kindly someone highlight what steps I should follow from here.
what could be the possibilities of this error?
Thanks & Regards
-Siddhant
Re: Petalinux Build Error 2018.1
Hi @siddh4nt
First you try clean and rebuild the project? use "petalinux-build -x mrproper"
If still error exists, kindly follow https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_1/ug1186-zynq-openamp-gsg.pdf  Refer chapter 3.
Kranthi
Best Regards
Kranthi
