lancec
Petalinux Busybox config being overwritten
Setup: Petalinux 2020.2 on Ubuntu 18.04
Main Problem & Question: I'm running "petalinux-config -c busybox" to enable CONFIG_FEATURE_FTPD_WRITE  and CONFIG_TCPSVD. However, when running "petalinux-build" my changes are being overwritten and I don't know why. How do I configure busybox so my changes aren't overwritten? When I check the running busybox version it is from Nov 15, 2020, so it looks as if Petalinux is installing a prebuilt busybox. Why?
Secondary Question: I noticed that busybox is disabled in the rootfs config but it still appears in the built rootfs. How is that? Who's installing it? (Note: I did try enabling it to see if my configuration above would stick around, but it didn't help)
hokim
In 2020.2, "petalinux-config -c busybox"  uses  internally "devtool modify busybox"
But it seems not to work correctly
Alternatively. do the following
$ petalinux-devtool modify -O busybox
$ petalinux-devtool menuconfig busybox
$ cd components/yocto/workspace/sources/busybox/oe-local-files/
$ mv devtool-fragment.cfg user.cfg
$ cd -
$ petalinux-devtool finish -f busybox $(pwd)/project-spec/meta-user
$ rm -fr components/yocto/workspace/sources/busybox/
$ tree project-spec/meta-user/recipes-core/busybox
├── busybox
│   └── user.cfg
└── busybox_%.bbappend
$ cat project-spec/meta-user/recipes-core/busybox/busybox_%.bbappend
FILESEXTRAPATHS_prepend := "${THISDIR}/${PN}:"
SRC_URI += "file://user.cfg"
$ cat project-spec/meta-user/recipes-core/busybox/busybox/user.cfg
# Thu Apr  8 05:17:44 2021
CONFIG_FEATURE_FTPD_WRITE=y
CONFIG_TCPSVD=y
maps-mpls
Mentor
Mentor
Take a look at this answer by @stephenm
It helped me on a different problem, and it might help you with your problem.  I hope it does help you!
*** Destination: Rapid design and development cycles ***
hokim
$ cd -
├── busybox
│   └── user.cfg
CONFIG_TCPSVD=y
lancec
@hokim
Thanks, that works. I see the result being the same as what was done in the reference @maps-mpls  mentioned. Just to confirm, the above is just the long form of what I was trying to do which is the following, right?
$ petalinux-config -c busybox
Follow on question I have now is: I have the file $(pwd)/project-spec/configs/busybox/inetd.conf (generated when I loaded my xsa). It has telnetd and ftpd enabled, but what ends up in my rootfs has them disabled. What is the relationship, if any, between the project/spec/configs/busybox/inetd.conf  and what ends up in my rootfs? Is it a bug in Petalinux or is there something else I'm missing? (note: I still pretty new to Petalinux, so if there are docs that go over this please point me to them)
hokim
"petalinux-config -c busybox" is identical to "petalinux-devtool modify busybox && petalinux-devtool menuconfig -a busybox"
But I found that "petalinux-devtool modify busybox" doesn't give correct result eventually. The problem seems to originate from yocto devtool python library
To avoid  the problem, I use "petalinux-devtool modify -O busybox && petalinux-devtool menuconfig busybox"
There are the same problems in "petalinux-config -c kernel" and "petalinux-config -c u-boot"
devtool-fragment.cfg  need to rename other name.
Oherwise, subsequent configuration overwrites the file
inetd.conf is found at three locations
$ find . -name inetd.conf
./components/yocto/layers/core/meta/recipes-core/busybox/files/inetd.conf
./components/yocto/layers/meta-petalinux/recipes-core/busybox/files/inetd.conf
./project-spec/configs/busybox/inetd.conf
The parsing order of  FILESEXTRAPATHS_pepend := "<path>" is the following
./build/conf/plnxtool.conf
./components/yocto/layers/core/meta-poky/recipes-core/busybox/busybox_%.bbappend
./components/yocto/layers/meta-petalinux/recipes-core/busybox/busybox_1.%.bbappend
Therefore inted.conf under meta-petalinux is used  finally
To fix it, you need to modify  project-spec/meta-user/recipes-core/busybox/busybox_%.bbappend like this(SYSCONFIG_PATH is  <peta-proj>/project-spec/configs)
FILESEXTRAPATHS_prepend := "${THISDIR}/${PN}:${SYSCONFIG_PATH}/busybox:"
It forces to  use ./project-spec/configs/busybox/inetd.conf
Refer to https://www.openembedded.org/pipermail/openembedded-devel/2015-October/103710.html
lancec
@hokim Thank you!
