puv97
Petalinux: ERROR: bitbake failed to configure kernel
Hi !
I'm trying to do the command petalinux-config -c kernel but it returns the errors shown in the images attached.
ERROR: Failed to config kernel.
I'm using petalinux 2018.3 and Vivado 2018.3 in Ubuntu 20.04 LTS. I tried different options that are in the forum:
- sudo apt-get screen
- chsh to change to bash
- Also I have seen that update to petalinux 2019.1 but, Can I use the project created using the 2018.3 version in 2019.1 ? Because there are many problems changing versions because I don't want to re-create everything.
Any idea? Thanks !
