12-02-2020 12:09 PM
Hi all,
I'm working with Petalinux 2015.2.1. I'm just trying to build Petalinux using the BSP provided by AVNET (Zynq MMP).ç
I have not modified anything at all. I just created the project and I'm trying to build it, and I'm having this warning:
[WARN ] dpkg: warning: 'start-stop-daemon' not found in PATH or not executable
Then, I get these errors:
[ERROR] ERROR: Invalid ELF file '/home/salva/petalinux-v2015.2.1-final/ZMMP_7100_PL2015_2/images/linux/vmlinux'
[ERROR] make[2]: *** [package-subsystem-FIT] Error 255
[ERROR] make[1]: *** [package] Error 2
ERROR: Failed to build linux
make: *** [linux] Error 255
I'm using Ubuntu 14.04.4 and I have installed all the dependencies according to the user guide.
I've also seen this thread but I did not add anything package, like unzip or any other.
This is my complete log:
salva@salva-VirtualBox:~/petalinux-v2015.2.1-final/ZMMP_7100_PL2015_2$ make
petalinux-build
INFO: Checking component...
INFO: Generating make files and build linux
INFO: Generating make files for the subcomponents of linux
INFO: Building linux
[INFO ] pre-build linux/rootfs/force_usb_power
[INFO ] pre-build linux/rootfs/fwupgrade
[INFO ] pre-build linux/rootfs/gpio-demo
[INFO ] pre-build linux/rootfs/peekpoke
[INFO ] pre-build linux/rootfs/uWeb
[INFO ] pre-build linux/rootfs/weaved
[INFO ] build system.dtb
[INFO ] build linux/kernel
[INFO ] update linux/u-boot source
[INFO ] generate linux/u-boot configuration files
[INFO ] build linux/u-boot
[INFO ] build zynq_fsbl
[INFO ] Setting up stage config
[INFO ] Setting up rootfs config
[INFO ] Updating for cortexa9-vfp-neon
[INFO ] Updating package manager
[INFO ] Expanding stagefs
[ERROR] dpkg: aviso: `start-stop-daemon' no se ha encontrado en el PATH o no es ejecutable
[INFO ] build linux/rootfs/force_usb_power
[INFO ] build linux/rootfs/fwupgrade
[INFO ] build linux/rootfs/gpio-demo
[INFO ] build linux/rootfs/peekpoke
[INFO ] build linux/rootfs/uWeb
[INFO ] build linux/rootfs/weaved
[INFO ] build kernel in-tree modules
[INFO ] modules linux/kernel
[INFO ] post-build linux/rootfs/force_usb_power
[INFO ] post-build linux/rootfs/fwupgrade
[INFO ] post-build linux/rootfs/gpio-demo
[INFO ] post-build linux/rootfs/peekpoke
[INFO ] post-build linux/rootfs/uWeb
[INFO ] post-build linux/rootfs/weaved
[INFO ] pre-install linux/rootfs/force_usb_power
[INFO ] pre-install linux/rootfs/fwupgrade
[INFO ] pre-install linux/rootfs/gpio-demo
[INFO ] pre-install linux/rootfs/peekpoke
[INFO ] pre-install linux/rootfs/uWeb
[INFO ] pre-install linux/rootfs/weaved
[INFO ] install system.dtb
[INFO ] install linux/kernel
[INFO ] install linux/u-boot
[INFO ] Expanding rootfs
[INFO ] install sys_init
[INFO ] install linux/rootfs/force_usb_power
[INFO ] install linux/rootfs/fwupgrade
[INFO ] install linux/rootfs/gpio-demo
[INFO ] install linux/rootfs/peekpoke
[INFO ] install linux/rootfs/uWeb
[INFO ] install linux/rootfs/weaved
[INFO ] install kernel in-tree modules
[INFO ] modules_install linux/kernel
[INFO ] post-install linux/rootfs/force_usb_power
[INFO ] post-install linux/rootfs/fwupgrade
[INFO ] post-install linux/rootfs/gpio-demo
[INFO ] post-install linux/rootfs/peekpoke
[INFO ] post-install linux/rootfs/uWeb
[INFO ] post-install linux/rootfs/weaved
[INFO ] package zImage
[INFO ] zImage linux/kernel
any help on this please?
