01-15-2020 10:02 AM
Hey all,
I have been using petalinux with a microblaze system. When configuring my petalinux project with a hardware description file the flash partitions I had previously set in the project-spec/configs/config file are overwritten.
When I run the petalinux-config step I get the following message.
INFO: Updating the flash partition size to 0x1160000 bytes, based on the bitstream in the HDF
This causes the following diff in project-spec/configs/config
- CONFIG_SUBSYSTEM_FLASH...AXI_QUAD_SPI_0_BANKLESS_PART0_SIZE=0x800000
+ CONFIG_SUBSYSTEM_FLASH...AXI_QUAD_SPI_0_BANKLESS_PART0_SIZE=0x1160000
- CONFIG_SUBSYSTEM_FLASH...AXI_QUAD_SPI_0_BANKLESS_PART1_SIZE=0x1B00000
+ CONFIG_SUBSYSTEM_FLASH...AXI_QUAD_SPI_0_BANKLESS_PART1_SIZE=0x1160000
- CONFIG_SUBSYSTEM_FLASH...AXI_QUAD_SPI_0_BANKLESS_PART2_SIZE=0x400000
+ CONFIG_SUBSYSTEM_FLASH...AXI_QUAD_SPI_0_BANKLESS_PART2_SIZE=0x1160000
01-21-2020 12:31 PM
Just wanted to share a quick update about this issue.
One way to work-around this is to copy in the HDF file into the directory project-spec/hw-description and the run the following command.
petalinux-config --oldconfig
