Petalinux HW-Accelerated Zynq in Vitis
Hello!
Im trying to build petalinux system with hw acceleration in Vitis but Ive encountered some problems.
Im using this tutorial to create petalinux system:
https://japan.xilinx.com/html_docs/xilinx2019_2/vitis_doc/Chunk375818786.html#hog1570652702356
But after modyfying DTSI with:
&amba {
 	zyxclmm_drm {
 		compatible = “xlnx,zocl”;
 		status = “okay”;
 I've an error with building it. What's the problem? is &amba...{} only in zynqMP/ultrascale?
What is alternative DTSI script for Zedboard? Where can I find other tutorials about building hw-accelerated platforms in Vitis?
Thanks for help and good day for you :)
Re: Petalinux HW-Accelerated Zynq in Vitis
Hello.
I am also using the same tutorial to create an Ultra96-V2 acceleration hardware platform.
I also got an error with petalinux-build in the same place.
I looked at "zynq zcu102 opencl linux" and entered the address and size, the error disappeared.
The platform isn't fully operational yet, so I don't know if it's correct, but for now, this work seems to avoid the error.
Here is my description.
&amba {
    zyxclmm_drm {
        compatible = "xlnx,zocl";
        status = "okay";
        reg = <0x0 0xA0000000 0x0 0x10000>;
Hello.
&amba {
    zyxclmm_drm {
        status = "okay";
I had the same problem. It's caused by using the wrong double quotes: “xlnx,zocl” should be "xlnx,zocl" and “okay” should be "okay".
So this will work:
&amba {
 	zyxclmm_drm {
 		status = "okay";
@immerzeelfjcThank you for pointing out the mistake in Xilinx's documentation, helped me save quite a bit of time. Hope somebody from Xilinx's staff in the forums marks this documentation error for correction so that people won't keep running in circles trying to find out why the official documentation do not work as expected.
Thank you all for solutions!
I hope that no one else will waste serval hours making project and get stuck because of wrong documentation.
Here is link to tutorial from Adam Taylor about creating hw-accelerated zynq platform: https://www.hackster.io/news/microzed-chronicles-microzed-zynq-7000-vitis-platform-creation-df25e1054fb6
Just remember about those "" symbols!
