Visitor bmurali
[Petalinux] How to NOT pack ramdisk as part of image.ub
How to force petalinux NOT to pack ramdisk as part of the image.ub?
I have selected the the rootfs image packing configuration to be SD card.
I have installed applications in the petalinux generated rootfs and copied to SD card. I want to use that.
Murali
Visitor bmurali
Re: [Petalinux] How to NOT pack ramdisk as part of image.ub
This is for Petalinux 2016.4
1) After petalinux-build go to <project-dir>/build/tmp/deploy/images/plnx_aarch64 or plnx_arm
2) Edit fitImage.its-1.0-r0. Remove the ramdisk@0 node from the images and configurations of the fitImage.its-1.0-r0 file
3) Run the following command:
mkimage -f fitImage.its-1.0-r0 ${plnx_project_folder}/images/linux/image.ub
Debraj
