dipl_om
Petalinux Import Hardware Configuration failure
i dont get the hardware imported form a .hdl file
I'm created a Petalinux Project like the reference guide tells and changed to the project directory.
the command: petalinux-config --get-hw-description=<path to hdl>
error: ERROR: You are not inside a PetaLinux Project. ...
Where is the failure? I dont get it.
The Petalinux Project directoryconsist of:
- .gitignore
- .petalinux
is that enough?
dipl_om
The Problem is Debian(7.8).
I install Ubuntu 14.4.2 with the same conditions and everything works.
sampatd
Make sure that after you generate the bitstream in vivado, you export the hardware to SDK.
File > Export > Export Hardware (Include bitstream)
File > Launch SDK
You need to execute the command from petalinux project directory.
suppose your petalinux directory is my_project, then
1. cd to my_project
2. execute the command
petalinux-config --get-hw-description = /path/to/*.hdf file
usually, you can find the *.hdf file in the hardware platform of the SDK workspace.
for e.g., if your vivado project is project_1
then you will find the *.hdf file in ../project_1.sdk/system_wrapper_hw_platform_0
dipl_om
I did it like you told me. Only the paths are diffrent because of the use of Windows with Vivado.
I think the problem isnt the .hdf file.
Is there a command to test if the petalinux project is valid or something?
sampatd
Are you using windows?
Windows is not a supported OS for PetaLinux:
Check page 9 of the following guide:
http://www.xilinx.com/support/documentation/sw_manuals/petalinux2014_4/ug1144-petalinux-tools-reference-guide.pdf
You can probably set-up a virtual machine.
dipl_om
The system i work on is windows with a debian in virtualbox on it.
This is the System Petalinux is installed(debian).
sampatd
That should be ok then.
Which version of PetaLinux and Vivado Tools do you use?
dipl_om
Vivado 2014.2
Petalinux 2014.4
sampatd
dipl_om
Okay i need a lower version of petalinux. I will test it if it works with this.
thank you
sampatd
Sure. Try with petalinux 2014.2 + Vivado 2014.2 and let us know.
dipl_om
install the version 2014.2 of petalinux but nothing changed
the same problem as before:
ERROR: You are not inside a PetaLinux project. Please specify a PetaLinux project!
Configures the project or the specified component with menuconfig.
dipl_om
sampatd
Good to know :)
